what size wrench for brakeline?andspecial tools needed?
your description of your brake problem is kind of fague
is it just a broken brake line
is it shoes and pads
calipers
rotors
drums
wheel cylinders
whats the problem
im assumign you dont have any tools at all if you are asking what specific size wrench you need
i suggest going out and buying a good selection of tools and a shop manual if you plan on working on your truck at all
this forum really helps out when your stuck but it wont do the job for you
calipers
rotors
drums
wheel cylinders
whats the problem
On my 96 F150, I believe the brake line wrench is a 2 sided box wrench with a slot cut in each side. There are 2 sizes (one on each side of the Box wrench).
When I remove brake lines, I usually brake them, and then replace them with new lines. The new lines are a couple dollars at NAPA or checker auto.
Then when my repair is complete I use the one man bleeding tool.
$5 at Napa.
Good luck,
Gene
$5 at Napa.
Good luck,
Gene
Spktyr
04-22-2016 10:29 AM
Necromancer
11-08-2015 08:51 AM
One Sock
01-25-2011 06:24 AM
