2001 F350 201000 miles spins over but no start
Ok guys, this morning I jump in the old girl, she fires right up. Then I back up to turn around and she dies. When I attempt to restart her, she just spins over fairly quickly with no firing. I check the oil level and she is a little low, so I add about a quart and try again. Still she will spin but not fire. This time there are no codes. I am in South Texas near Victoria.
Any ideas wher to start my journey?
Ted
Ted
Ted
Ted
When it died, was it like it was fuel starved (sputter?) or like a flip of the switch shut off?
Could possibly be the fuel bowl heater shorted out and popped the #30 fuse, which also kills power to the PCM. She'll spin but not fire with those conditions. If #30 is popped, first unplug the fuel bowl heater (white plug IIRC on the back lower side of the fuel bowl), replace the fuse, and you're set.
Ok guys! I am back home early! I check fuel pump it is humming away. Then I check #30 fuse and it is not blown. Then I get idea after reseating the fuse to try to start and she spins like mad and fires off. I am at a loss now. She is running and all very smoothly. No SES light or anything else. I am currently letting her run for a little bit. This is a little perplexing. I have never experienced such an event.
Shut it off and she fires right back up. I will have to check it again in the morning. It does sound like I have a little knock in the motor lately though.
I will keep everyone informed of the next few issues I have.
Ted
Ted
rlpatte
02-01-2022 05:10 PM
1468LP
11-27-2010 06:53 PM
kdokey
07-04-2009 02:01 PM
