Engine died, now won't restart...
I was driving down the road when my truck ('92 F-150 302 E4OD) just died. It's happened twice in the past 3-4 months, but it would restart immediately. This time, it won't restart. I had a little electrical smelling smoke come outta the dash, and now I'm almost positive I'm not getting fire from the coil. I can't find any burnt wires or anything though. Any ideas?
Thanks.
Thanks.
I took the coil wire off the distributor and put a spare plug in it and there was no spark.
Yes, it cranks.
Yes, it cranks.
There are multiple contacts on the ignition switch. Likely the starter is fine, but the ignition side is toast.
If you look closely under the dash, above the column, you'll find the switch module. You can likely unbolt it, pull it down and check it while in the truck. Then you might be able to "sniff" it and see if it smells burnt. You mentioned that the majic smoke came out of the dash area.
I've never had mine down, but had to tap into it when I installed my remote start. If it is the switch(kinda a common issue), they are cheap and easy to replace.
First, sniff it to see if it smells burnt. That is the quick way.
If you could come up with a Chilton book, you could check the wiring and possibly jump the ignition side to see if truck runs. There are like 4-5 big wires, and a few small ones, and I don't have anything handy at work to tell you what they are. Not sure if there is something online?
staunton
22
03-19-2018 05:18 PM
tjs_79ford
09-20-2009 11:30 AM
dillonduncan
05-07-2007 03:26 PM
Quackhead94ranger
07-02-2005 02:40 PM
