No breather vent in rear axle?? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-10-2011, 11:32 AM
knightrider955's Avatar
knightrider955 knightrider955 is offline
knightrider955 is starting off with a positive reputation.
I own a 2003 Superduty. I was putting my boat in a lake with a real shallow launch so I had to back in until my back tires were completly under water. Afterwards I wanted to make sure the vent tube on my rear axle was long enough but I couldnt find it. Is there not a vent on my rear axle?
Old 08-10-2011, 11:54 AM
Rongold's Avatar
Rongold Rongold is offline
Rongold is gaining momentum as a positive member of FTE.
Rear Axle Breather
I just looked at my 03 F-250, and I have one. It's on the left (driver's) side. Look at the tee where the rear brake hose meets the 2 steel brake lines. It's incorporated into that tee. On mine, the vent hose goes up from that tee to under the bed.
RON
Old 08-10-2011, 12:04 PM
mtdigger's Avatar
mtdigger mtdigger is offline
mtdigger is starting off with a positive reputation.
Agreed..if there was no vent...your driveway would be soaked in gear lube every time you parked. My 99 dually has the tee as well
Old 08-10-2011, 12:18 PM
I found it. It was covered with grim and dirt so I didnt see it before. Unfortunatly the is no hose. So should I be worried? It wasnt underwater for more than a few minutes. I drove it 200 miles home afterwards. No noises or anything.
Old 08-10-2011, 12:20 PM
mtdigger's Avatar
I would drain n refill, water may not play well in there
Old 08-10-2011, 12:26 PM
dchamberlain's Avatar
dchamberlain dchamberlain is online now
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
Time for a rear fluid change. Not even considering that the vent was underwater this time, how long has it been going without a vent tube, which could allow dirt, water spray from a wet road, whatever into the differential.
And you'll want to get a vent tube on there. If you look around, the original tube might be hanging around loose under there. It would have gone up to a open V shaped fitting connected up under the bed somewhere.
Old 08-10-2011, 12:28 PM
SteveH-CO SteveH-CO is online now
SteveH-CO has a good reputation on FTE.SteveH-CO has a good reputation on FTE.SteveH-CO has a good reputation on FTE.
A hot diff soaked in cold water will pull a vacuum and potentially suck water in the disconnected diff. vent. You need to check/change it immediately, and possibly change it twice. Getting the diff good and hot with the new lube should drive off any remaining water, so I'd recommend a road trip after you change the oil.
Old 08-10-2011, 12:38 PM
Ok I'll change it. I cant find the disconnected hose anywhere so I gonna have to buy a new one. Who knows how long its been gone. Ive only owned the truck 5 monthes. Any idea what oil I need to put back in it??
Old 08-10-2011, 12:43 PM
Assuming it's a single rear wheel F-350.
75W-140 Synthetic Gear Oil and a friction modifier for the limited slip clutch pack.
Some companies (like Mobil 1) will make the oil with the friction modifier already in it. It should take about 3 1/2 quarts.
You'll also need some black silicone gasket maker, to seal the cover back up.
mtdigger's Avatar
Old 08-10-2011, 09:15 PM
Rongold's Avatar
REAR AXLE
While you have the cover off, I would lift each side of the axle with a hydraulic jack under each shock mount 1 at a time for a few minutes. This is just in case water got into the axle tubes. If the rear end was under water for a few minutes, you might have quite a bit of water in there.
RON
Old 12-21-2011, 05:28 PM
buterbn buterbn is offline
buterbn is starting off with a positive reputation.
I know this is old, but can't find much info on this topic.
My breather tube has fallen off the tee. I have the tube, however I can't figure out where to connect the Y fitting on the other end?
Somebody said it connects up under the body. Does anyone have a photo or know where this connects?
2002 F-250 5.4L
Thanks
Old 12-22-2011, 03:07 AM
A/Ox4's Avatar
A/Ox4 A/Ox4 is offline
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
Excuse my ignorance. Entry level question here!
Why does the rear diff have a vent tube? Does the front? I was unaware of this until today.
Old 12-23-2011, 08:13 PM
dagren99 dagren99 is offline
dagren99 is gaining momentum as a positive member of FTE.dagren99 is gaining momentum as a positive member of FTE.
Know for sure the rear has a vent and almost sure the front does to but not 100% sure - vent is to allow gasses to escape as the oil in the pumpkin heats up - if they weren't vented the pinion seal would get blown out. (Ask me how I know - plugged vent on a 99 F150 + 150 miles @ 65mph = blown pinion seal and a diff soaked in gear oil)
Old 12-23-2011, 09:05 PM
A/Ox4's Avatar
9 ECHO 1
Could this cause a blown inner axle seal? My front left inner axle seal leaks.
Check those axle vents Mikeman Explorer, Sport Trac, Mountaineer & Aviator 0 05-17-2014 01:06 AM
Fuel tank vent valve alchemist1 1973 - 1979 F-100 & Larger F-Series Trucks 0 01-01-2013 05:00 PM
F-350 Axle Vent Hose Routing Spktyr 1987 - 1996 F150 & Larger F-Series Trucks 5 12-06-2012 12:05 AM
Rear axle vent? 81custom350 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 10-24-2012 07:53 PM
diff vents collinft 1973 - 1979 F-100 & Larger F-Series Trucks 4 09-25-2011 02:32 PM
Tags
2006, axle, breather, bronco, classic, diff, differential, end, f250, f450, ford, hose, rear, sport, trac, vent, vents
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
