No breather vent in rear axle??
Naah the inner seals are in the axle tube - hard to do much to them when changing the fluid.
Have you used 4x4 much since?
One of ours leaked a little (just enough so the seal/knuckle was damp w oil not dripping though) after a fluid change thought I might have over-filled it so we checked the level and it was fine but then we drove it in 4x4 a couple of times and it hasn't leaked since -we figure maybe draining the fluid and rotating the pinion & spider gears for inspection w/o full oil could have introduced something into the seal or disturbed it and driving it drove/worked it out.
70-360fe
12-25-2013 09:55 PM
OldWoodsDiesel
07-17-2013 09:28 PM
idiggplants
05-29-2009 03:54 PM
bcsbadboys
07-30-2002 03:17 PM
