2005 Escape AC Clutch - Ford Truck Enthusiasts Forums
Old 08-10-2011, 06:35 AM
jbtecnico1 jbtecnico1 is offline
jbtecnico1 is starting off with a positive reputation.
Hello Forum,
Post started here, serp belt tensioner suspect:
http://www.ford-trucks.com/forums/10...04-escape.html
Now is bearing on AC clutch pulley.
Any opinions if I should replace the assembly or just the pulley with bearing bearing, or just the pulley?
I found the coil/pulley/bearing/clutch assembly for $99 (new).
Thank you,
Jim
Old 08-10-2011, 08:02 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
My old 97 F150 had the pulley bearings fail. I replaced the pulley and hub and it's still running fine about three years later.
I haven't had the fun of doing the same operation on an Escape yet, so I don't know what type of space limitations might be in play. If it looks like you have enough room, I'd replace the pulley and hub and leave the coil alone.
Old 08-10-2011, 11:07 AM
Thanks SHO89...I bought the clutch assembly today, after market. Very good instructions for disassembly/reassembly. Coil simply prys off, presses on, so I will replace entire assembly. Nice working space on the Escape too, after removing plastic lower splash guard - doing all the work from the ground up. Will report final results.
Old 08-10-2011, 10:58 PM
Update - job done. New tensioner, new serp belt, new AC clutch assembly. Smooth and quiet, bearing noise gone and AC "output" perked up with new clutch. No major issues. I will admit I needed a hand with the serp belt - needed someone to hold max and constant against the tensioner while I managed the belt over the small idler pulley...just couldn't quite get it alone, with the new belt. Thanks Forum for your inputs.
Ac compressor seized question about options marcogyver 1997-2006 Expedition & Navigator 2 09-10-2016 09:33 PM
Serp Belt Tensioner - 2004 Escape jbtecnico1 Escape & Escape Hybrid 7 08-10-2011 08:15 AM
Replaced Serp Belt -- Tensioner pulley clicks . . . normal? JoeVR5 Ranger & B-Series 12 04-14-2010 07:21 AM
Serp belt tensioner...RH or LH threads?? Crew-it Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 03-31-2010 12:40 PM
95' 5.8 tensioner pulley problem 95F150Guy 1987 - 1996 F150 & Larger F-Series Trucks 4 01-30-2010 11:01 PM
Tags
05, 2005, ac, air, belt, change, clutch, condition, conditioner, escape, ford, repair, replace, repoval, tensioner
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
