HVAC vac line possibly broke?
Old 08-10-2011, 08:48 PM
hojolabo's Avatar
hojolabo
hojolabo is offline
03' F-150 FX, 5.4 std control HVAC
My HVAC air comes out of the defrost only, after ruling out all else I believe one of two things..
1. a broken line (somewhere) after entering through the firewall, not likely.
2. the control switch letting the vac bypass somehow.
I've tried pulling vac on the supply line under the hood just b-4 going through the firewall and get nothing, is it possible that the control switch is letting the vac pass through?
I haven't checked the vac at the switch yet but have at the control module under the dash (alongside the throttle linkage) that controls the bypass door and there is no vac, I also hear a clicking sound coming from under the dash in the area just left of the glovebox, almost like a static sound and definitely under the dash.
Is it possible that there is a check valve under the dash between the point of entry and the control switch causing the problem, and where might it be located?
Any help will be greatly appreciated.
BBslider001
17
07-16-2015 05:06 PM
BlueOvalRage
12-16-2011 12:41 AM
murph1
1997 - 2003 F150
10-10-2008 09:57 AM
krunk357
03-23-2008 01:43 PM
mach2race
1999 to 2016 Super Duty
07-21-2006 12:49 AM
Quick Reply: HVAC vac line possibly broke?
