low boost troubles
low boost troubles
I've did some searches and haven't found anything to solve my problem. I keep getting the low boost code on my truck
Truck has 133k, HPx, FRx, new boots and clamps,plenium inserts, dp tuner set on 60tow, 4in down pipe/5in exhaust. Truck makes 18-19psi and will get to 1200 pre turbo on the egt, and it smokes.
I've done the leak check to 15psi and found nothing, but I didn't soap anything just listened. I'm wondering if the EBPV is letting some boost out the pipe. What do you think, what should I check. Thanks in advance.
Jonathan
Jonathan
The line to the map had a small leak in it at the spider and I fixed that.
If I understand the EBPV right it is what opens when the truck is cold and "dumps" into the exhaust so the truck will not make any boost. Correct me if I'm wrong. Could it be open some, causing my low boost and higher egt's. Or what else should I look for?
It did this before I replaced the ic boots/clamps and inserts. I also checked the charger for play when I had it apart and everything looked good.
It is possible that your problem is the waste gate or the actuator which is known to be weak.
When I bought the truck a couple years ago the red line was unhook, I hooked it bad and its been that was ever since.
Why dont you do a test with the red line hooked to the wastegate and one test with the red line unhooked and plugged. See if there is a difference in the two in the amount of maximum boost you can make
MR5x5 the wheel looks and feels good, I just did boots, plenuim insert, HPx, FRx and rebuilt the fuel bowl less than a month ago and I checked it then.
I called clay at riffraff to see what he thougth, he said check the up pipes, I did and no leaks.
So I deceided to do anther leak check and the truck wouldn't hold any psi, it was leaking were the turbo meets the spider! I'll finish putting it back together tomorrow.
It makes 24 on the 80e tune with the red line pluged n, 26 on 80e with the red line off. Both numbers are with the leak. And I don't have a boost fooler.
Jonathan
Jonathan
Without a boost fooler the truck will "de-fuel" iself automatically around 21 psi and you will go no higher.... The numbers you're giving are within reasonable tollerance of that number, although they are a bit to extremes of expected tollerances.
Assuming you want to get more boost...and who wouldn't there are a number of place to pick one up. I'd start with sight sponsers myself. 10 minute install.
