1978 Ford Crew Cummins Swap - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 02-09-2012, 08:02 PM
Higbean's Avatar
Higbean Higbean is offline
Higbean is starting off with a positive reputation.
Finally finished these battery boxes. Had a bunch of fun building them.
  #62
Old 02-09-2012, 08:23 PM
andyort's Avatar
andyort andyort is offline
andyort is starting off with a positive reputation.
Pretty cool keep it up!
  #63
Old 02-09-2012, 08:26 PM
firemedicober's Avatar
firemedicober firemedicober is offline
firemedicober is starting off with a positive reputation.
Battery Boxes look great!
  #64
Old 02-12-2012, 10:29 PM
Higbean's Avatar
Here is the trans mount pics. I used what was left of the Dodge mount.
Got the 205 tacked up. Cut the rivets off a stock cross member and moved the front hole to the back hole and just need to drill four for the rear. Working out pretty slick. And yes, I need to finish painting the ugly old thing.
Also finished the Intercooler mounts. Just used some angle iron and made rubber standoffs. Went rather easily and ended up sturdy.
I finished the tubes for the IC as well. I used the stock pipe from the drivers side and cut it at the lowest elbow. I stopped by an exhaust shop and grabbed a couple of flared pieces and a foot or so of 3" for the Ford IC. I took the elbow off the turbo, cut it down and tig'd it. Used the left over part from the other side and flared it in the same fashion. Hopefully I'll be ordering drive lines by the end of the week from Tom Wood's. Still gotta figure out the gas pedal, linkage, wiring and return line. And exhaust. And mount the air cleaner. And transmission lines. But that's it. Oh and A/C.
  #65
Old 02-12-2012, 10:47 PM
andyort's Avatar
Good Idea. Looks good.
  #66
Old 02-13-2012, 08:46 AM
teds74ford's Avatar
teds74ford teds74ford is offline
teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.
That doesn't look like any 205 I've seen. What did you get it out of?
  #67
Old 02-13-2012, 09:22 AM
That transfer case looks like a Dana 24, used in the earlier fords... Pretty solid unit either way.
  #68
Old 02-13-2012, 09:25 AM
Higbean's Avatar
It's a really early 205. OMC used ford 205s in their peach shakers and that's what this is out of.
  #69
Old 02-13-2012, 09:53 AM
Higbean's Avatar
Well crap, I asked a few guys about it around here and they all swore it was a 205, but digging around it looks to be a 24. Kinda sucks. I'll have to look around and find a 205 I guess. Apparently parts are hard to find for these.
  #70
Old 02-13-2012, 10:19 AM
Well the good news is I think if you find a divorced 205 it will bolt up to the mounts you've already fabbed. ��
  #71
Old 02-13-2012, 10:28 AM
Higbean's Avatar
Yeah, but I was having a hard time finding one when I finally got this one. I was hoping to have this thing driving by the end of the week. I guess I'm headed to the pick and pull yards to play in the mud.
  #72
Old 02-13-2012, 01:41 PM
Well I have an extra Dana 24 and a a518 sittin around but don't know what state you're in, I was doin the same swap but still debating about a zf5 or nv4500, real interested to see how yours drives. Looks great man!
  #73
Old 02-13-2012, 01:42 PM
Is that a powersmoke intercooler?
  #74
Old 02-13-2012, 01:47 PM
Higbean's Avatar
Yep. 99 power stroke.
  #75
Old 02-13-2012, 01:56 PM
Higbean's Avatar
I'm in Northern California.
1973-1979 Ford Cummins motor mount pics Higbean Engine Swaps 104 03-03-2017 05:50 PM
I put a Ford V10 in my 66 & ....... topscrt 1961 - 1966 F-100 & Larger F-Series Trucks 37 05-12-2013 12:08 AM
1973-1979 Ford Cummins radiator/intercooler set up Higbean Engine Swaps 2 09-18-2012 10:13 PM
Before and after pics...Lift and Tires big orange beast Excursion - King of SUVs 16 09-27-2010 03:12 AM
Looking for replacement Heater/ A/C flexible ducting for Factory A/C swap - Pic's Crew_Cab_78 1973 - 1979 F-100 & Larger F-Series Trucks 12 11-28-2009 09:40 AM
Tags
1938, 1978, 4x4, 59, 78, cab, conversion, crew, cummins, f100, f250, ford, frame, sedan, swap, width
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
