1978 Ford Crew Cummins Swap - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 01-03-2012, 09:04 PM
Higbean's Avatar
Higbean Higbean is offline
Higbean is starting off with a positive reputation.
Quote:
Originally Posted by teds74ford View Post
Looking good. It also looks like you did build a front hitch as well
Yep. Forgot to post pics.
  #47
Old 01-04-2012, 09:55 AM
teds74ford's Avatar
teds74ford teds74ford is offline
teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.
Looks good. Did you cut the frame ends off?
  #48
Old 01-04-2012, 10:05 AM
Higbean's Avatar
Yeah. Decided to go with a stock bumper and z the frame horns.
  #49
Old 01-06-2012, 07:47 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.
Hahaha - I hear ya trying to find pics in my thead. Good thing they are easy to find in my photobucket, or even better in my personal build pics folders here on the home comp.
If you guys ever need any specific pics & can't find them - just feel free to ask.
As for the time/$ question - oh boy... I've got hundres, if not thousands of man hours in mine and a TON of $$ in it. Thought not as much as people would think as I'm a cheap a** and buy things used or build my own
  #50
Old 01-29-2012, 10:38 PM
Higbean's Avatar
Got the floor pans and 38 gal tank in.
  #51
Old 02-02-2012, 12:00 AM
Higbean's Avatar
Bought a couple batteries and installed the Eastwood thermo-coustic sound deadener today. Man, what a tedious job that was. Now to build battery boxes and start to wiring.
  #52
Old 02-04-2012, 09:10 PM
Higbean's Avatar
Worked on these today. Almost done, just need to fab up the straps.
  #53
Old 02-04-2012, 09:29 PM
teds74ford's Avatar
Looking good!
  #54
Old 02-06-2012, 11:31 PM
firemedicober's Avatar
firemedicober firemedicober is offline
firemedicober is starting off with a positive reputation.
Cummins Crew Cab
Hey Guys,
Ive been reading your posts and enjoyed all the build pics, My 78 crew was a 2wd and ive done a frame splice, Ill try to link my pics of the job, but now its out with the 429 and time for the 12 valve to go in. My question to you guys is did you go with the divorced transfercase and use the 2wd dodge trans or opt for a married unit? Thanks for your time.
My kids love the old beater, the big block puts my 2 y/o to sleep... either that or I have an exhaust leak...dunno.
  #55
Old 02-06-2012, 11:56 PM
Higbean's Avatar
Quote:
Originally Posted by firemedicober View Post
My question to you guys is did you go with the divorced transfercase and use the 2wd dodge trans?
Yeah I went that route. Guess I never posted pics of how I did the trans mount. Still need to do the transfer case cross member.
  #56
Old 02-07-2012, 02:41 AM
So, how does that transmission run out? Does it shift all crazy like my 98 cummins did? Im debating on weather to spend the money on a NV 5 or 6 speed or use the A518 and the divorced transfercase. As with most of us truck lovers with families got a limited budget so the 2wd trans sounded like the simple option... any thoughts? Just dont want a crummy transmission after all the work. I have a 92 12valve and the A518 along with a dana 24 transfercase right now but im debating on wether to go divorced NP 205, or find a mated case and dodge transmission or manual..help me out
  #57
Old 02-07-2012, 10:52 AM
Higbean's Avatar
Well, if you read through this thread, you'd know that mine is not finished yet so I couldn't tell you how it "runs out". Do a search or start your own thread. Lots of stuff to read. I went with the A518 because it is what I had. If I had to do it over I'd find the 4x4 version A518 and buy an adapter for the married 205. I asked around but didn't know that was an option until I had the 12v and trans mounted.
  #58
Old 02-07-2012, 10:26 PM
redzcstandardhatch redzcstandardhatch is offline
redzcstandardhatch is starting off with a positive reputation.
Excellent stuff
  #59
Old 02-08-2012, 07:31 AM
"Top Fuel" Bender's Avatar
"Top Fuel" Bender "Top Fuel" Bender is offline
"Top Fuel" Bender is gaining momentum as a positive member of FTE.
I'm still working on mine
but I'm doing the 4x4 a518 mated to a np205
thought about doing the divorced but the extra length of the 2wd case plus the middle driveshaft puts the t-case back pretty far IMHO
plus I hear stories of driveline vibration and need for bracing the t-case to the trans
I'm not familiar on the dana24 but is A518 2wd or 4wd?
if it's 2wd you just need the rear trans case and output shaft to convert it to 4wd
  #60
Old 02-08-2012, 03:20 PM
andyort's Avatar
andyort andyort is offline
andyort is starting off with a positive reputation.
Lookin Good buddy. I subscribed Looks like you have a handle on it, Fab looks good. Ill stay tuned. May have some questions coming up soon.
1978 Ford Crew Cummins Conversion - Dodge Cummins Diesel Forum
1973-1979 Ford Cummins motor mount pics Higbean Engine Swaps 103 01-19-2016 02:36 PM
Intermediate Steering Column Modification OkieFromMuskogee 1987 - 1996 F150 & Larger F-Series Trucks 11 08-31-2015 06:31 PM
iDash... willietwosix 6.0L Power Stroke Diesel 7 02-27-2012 02:58 AM
what kind of car is this? jjtoday General Automotive Discussion 8 07-29-2010 01:25 PM
Why Fords need to be tough!! KRDiesel New Mexico Chapter 16 05-23-2008 10:38 AM
Tags
1938, 1978, 4x4, 59, 78, cab, conversion, crew, cummins, f100, f250, ford, frame, sedan, swap, width
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
