Another Glow Plug Question
Old 08-09-2011, 09:07 PM
mlouritt's Avatar
mlouritt
mlouritt is offline
I have a 1990 F350 7.3 with an ATS turbo that I've owned for about a year. About a month ago the glow plug relay began to chatter on cold starts and the WTS light would cycle about once per second. It was apparent the glow plugs were not cycling on. I replaced all 8 glow plugs with Motorcraft/Beru plugs with no change. I then checked the wiring harness and glow plug connectors for electrical continuity. I replaced all 8 connectors and repaired the damaged glow plug harness, there were 3 bad connectors and 2 bad splices in the harness. No change. I next replaced the glow plug relay, no difference. Next I replaced the glow plug controller and still no difference. The glow plug relay continues to cycle, the WTS light cycles about once per second, and the glow plugs are not receiving power to cycle on at cold start. What should I look at next??
Old 08-09-2011, 09:48 PM
86f250XLT-4x4's Avatar
86f250XLT-4x4
86f250XLT-4x4 is offline
I and many others will probably suggest it's what is on mine and it works nice is a push button for the glow plug relay mine is set so when you hold the button they are on
Old 08-10-2011, 01:31 AM
starmilt's Avatar
starmilt
starmilt is offline
You may have a ground problem.
Old 08-10-2011, 08:03 AM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,081 Likes on 2,151 Posts
yup. i would check the grounds read good.
new relay and controller with new harness leaves only power into the unit. if you have 12volts in, the only thing left is grounds.
Old 08-10-2011, 09:49 PM
mlouritt's Avatar
mlouritt
mlouritt is offline
I tried a jumper from the glow plug controller ground at the base of the controller to the negative battery post, no difference. I checked voltage at the glow plug relay, 12.78 volts at the battery and 12.40 volts at the relay. Should'nt the voltage be the same? When I turn the ignition key on to check the glow plugs, the voltage at the relay varies all over from 8.5 to 12.8, voltage to the glow plugs is 0. Bad ground or bad wire feeding the relay? The wire harness feeding the relay has been spliced and wrapped in shrink wrap, the connection seems good.
Old 08-11-2011, 10:59 PM
charleswood6969's Avatar
charleswood6969
charleswood6969 is offline
You didn't do something like wrap the threads of your glow plugs in teflon tape or something like that which would prevent the glowplugs from getting a ground, did you?
Old 08-14-2011, 05:55 PM
mlouritt's Avatar
mlouritt
mlouritt is offline
I found my problem. The "seems good" connection feeding the glow plug relay is bad, I'll need to replace the wires. I also found the ground at the glow plug controller was not really very good. A combination of several bad electrical connections was the problem. Thanks to all for the help.
Old 08-15-2011, 03:01 PM
catbird7's Avatar
catbird7
catbird7 is offline
My wiring harness was toast and created more problems than it was worth. I bought a new one from Uhaul Truck parts. I think they still have some of these in stock. Works great!
Romel77
10-30-2018 08:56 AM
Bvill01
03-03-2016 10:27 AM
whenry912
13
11-16-2011 06:35 AM
'86Clifford
General Diesel Discussion
09-06-2007 08:57 PM
watermanh
01-03-2006 09:24 PM
Quick Reply: Another Glow Plug Question
