5.0HO viable engine?
Old 08-11-2011, 10:09 PM
Poison Oil Racing's Avatar
Poison Oil Racing
Poison Oil Racing is offline
Old 08-11-2011, 10:39 PM
bsiebert's Avatar
bsiebert
bsiebert is offline
Agreed. EFI > Carb in many ways.
Old 08-12-2011, 01:01 AM
TOPHER1978F150's Avatar
TOPHER1978F150
TOPHER1978F150 is offline
Originally Posted by meborder
So long as he has the matching flywheel and damper for the motor, it shouldnt matter what it is hooked up to, so long as the bolt patterns are the same. The imbalance is attached to the flywheel, and the clutch pressure plate should be a neutral balance.
I would think that if he has the origional damper to the new motor, then buys a clutch set for his truck with that motor, then gets a flywheel for a truck the same year as the motor .... it should all work. assuming that motor and tranny combo was ever available.
I read this as you where saying he could put his 28 oz. imbalance flywheel/ harmonic balancer on a 50 oz imbalance motor.
Old 08-12-2011, 06:56 AM
meborder's Avatar
meborder
meborder is offline
I think i see where you might read it that way....
Assuming that the motor comes from an 85 mustang, you will need to get the damper from the mustang. If you're lucky, the 'stang will be a manual, and you can use the flywheel that is on the motor now. If not, then you will have to find a flywheel for an 85 'stang.
to mate to the transmission, you will need to buy a clutch set for your year transmission bolted up to a 302, assuming that trans was ever bolted up to a 302 from the factory.
the clutch you have might bolt up and get you by. I don't know much about the 300 I6 .... but if all the bolts from the clutch cover match the flywheel for the 85 motor, it will probably work. maybe not ideal, but will get you by until you can get the right clutch for a v8.
I know in the chevy world, for a mild 350, the v6 clutches hold fine in an s10. even the 4banger clutches bolt up, but dont hold the torque.
I'd try to find a v8 clutch set for your trans if you can, then you dont have to replace the clutch for a long time after you bolt it all up.
this should be a very doable and worth while swap .... I'm not sure about the engine mounts, but i would think that if you got mounts for your year truck with a 302, everything should work ...... not sure, but that's usually all it takes.
64shrtbed
20
04-09-2008 07:23 PM
Kylet8020
13
04-29-2007 07:57 PM
Scifi266
03-31-2007 12:11 AM
southernreb05
12-08-2004 12:30 AM
F-150Guy
19
12-05-2004 09:13 PM
Quick Reply: 5.0HO viable engine?
