Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 6.2L V8
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8 SPONSORED BY:
  #1 (permalink)
Old 08-09-2011, 01:59 PM
Buckholz Buckholz is offline
Garage is empty, add now
Buckholz is starting off with a positive reputation.
Message Center "power reduced to lower temp"
or something close to that.
Towing 9,000lb travel trailer with 4 dirtbikes in the bed up a pass from 7000' to 9000', 6.2L 3.73 '11 early model F350 running 91 octane fuel. Was in 2nd gear, WOT, about 5800rpm for about 10 minutes, watched the temp gauges on both tranny and coolant climb, but never entered red zone. Fan clutch cycled on for about a minute or so prior to the warning. Right as I crested the summit, the warning appeared, and I was rolling off the throttle anyway.
My fan clutch does a weird wowowing noise, not like previous diesel fords.
Headed in on Thur for the transmission update. Wonder if the powertrain flash will affect this potential overheating performance? Anyone else towing heaving and high elevation seen this warning?
Truck still runs super, very happy. Tows great, fuel economy down roughly 25% from my ol' 6.0L diesel, but love the gasser....
  #2 (permalink)
Old 08-09-2011, 03:32 PM
Sargemo105's Avatar
Sargemo105 Sargemo105 is offline
Sargemo105 is starting off with a positive reputation.
No. I just got back from a CO trip where I pulled my 9200lb TT over 10,000 Wolf Pass. I had to go to M and shift between 1 & 2 to maintain a 30mph pace. I didn't let my rpm's exceed 5000. My signature doesn't show up on posts from my phone, but I too have the 3.73's.
  #3 (permalink)
Old 08-09-2011, 04:14 PM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2011 Ford F-350
2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all
I wouldn't expect the trans TSB to correct anything heat related. If you were saying you were having issues shifting into 3rd then I could maybe see the TSB correcting it, but it sounds like gravity's talons were dug deep into your trailer!
I went through a similar situation in my '00 when I moved out to PA from Phx. I was dragging an overloaded U-haul trailer with my truck (37" tires and 3.73 gears) up along the Mogollon Rim. My truck was wrapped out in 1st gear, just had the pedal mashed for about the same length of time you did. "Back then" though, you didn't have any dash messaging, you waited for the idiot gauge to instantly peg or the trans to blow up.
Ah the good ol' days!
__________________
Matt
2011 F350 - 6.2 CC, LB, 4.30s, Lariat Ultimate pkg, FX4, Amp steps, Lockpick, AC LC6i, JL HD900/5, JL 13TW5, JL C5-570's, Bilstein 7100 stabilizer, Rancho RS9000XL's, Leveled w/ 35" Toyo M/T's and 5 Star tuned
**Sold - 2000 F250 V10, 6.5" Pro Comp, 37" Toyo MT's
  #4 (permalink)
Old 08-09-2011, 07:32 PM
fordmdb's Avatar
fordmdb fordmdb is offline
PREMIUM SPONSOR
fordmdb has a very good reputation on FTE.fordmdb has a very good reputation on FTE.fordmdb has a very good reputation on FTE.
This is just Fords way of reducing power (rpms) when oil / coolant temp rises. Sounds like it was working perfectly.
Heres a couple of tables out of a max rev limiter section on a 6.2L strategy.
oil temp - rpms max allowed
400f- 4499
300f- 4500
200f- 5000
100f- 5550
under 100f- 5850
coolant temp-rpms max allowed
297 - 4499
293 - 4500
287- 5000
284- 5500
280- 5850
__________________
Custom Tuning for F-E-Series Engines 6.8L V10 / 5.4L V8 / 4.6L V8 / 6.2L V8 / 5.0L V8 / 3.7L V6 / 3.5L EB and more!
SCT Custom Tuning Dealer
www.5startuning.com email me here:mike@5startuning.com 843-536-1244
  #5 (permalink)
Old 08-09-2011, 07:56 PM
2011 Ford F-350
Too bad the gauge screen doesnt give us anymore than the trans temp. That's good info though Mike.
__________________
Matt
  #6 (permalink)
Old 08-09-2011, 10:37 PM
RadRick RadRick is offline
RadRick is starting off with a positive reputation.
I read about this in the owner's manual when the 2011's first came out. It states that both the 6.2 and 6.7 have a feature that reduces power under certain high load conditions to protect the engine, but not on the 6.8. The manual gives the impression it would be normal for this to happen frequently, but you are the first person I've heard make mention of it.
  #7 (permalink)
Old 08-10-2011, 08:29 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
I think we have a winner here for an entry in the 6.2L tech folder
Posted a link to this thread in the Tech folder suggestions thread. GREAT INFO Mike!
Reps sent.
__________________
- art k. - Moderator for the Superduty, V10, 6.2L and FE forums
'13 Taurus SHO 3.5L Ecoboost w/Perf Pkg
'01 F250SD SC SB XLT V10 4x4 Volant CAI Hedman headers 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see. ®
  #8 (permalink)
Old 08-10-2011, 08:54 AM
Super info Mike. Thanks!
Anyone else that has gotten their SD hot enough, does your fan clutch cycle in and out rapidly, a wowowing noise instead of a constant blower noise once the engine management software says engage the fan?
  #9 (permalink)
Old 08-10-2011, 09:10 AM
DirtEngineer DirtEngineer is offline
DirtEngineer is starting off with a positive reputation.
I've hauled my 8000lb TT up some steep grades, and had the engine running at 5000+rpm, but never for this long. Never had the power-down issue yet either. However, I have heard the fan clutch engage, but no cycling. Just fires up for a couple minutes, then shuts down. Also, no noises that caught me off guard either.
  #10 (permalink)
Old 08-14-2011, 06:46 PM
Radiator and AC condenser pretty plugged with bugs, pressure washed. Hope that helps for my next tow. Plus I had TSB 110611 performed to update tranny. Will report.
  #11 (permalink)
Old 10-08-2012, 02:34 PM
jimlightner jimlightner is offline
2012 Ford F-250
jimlightner is starting off with a positive reputation.
Any experience with oversized transmission pan? Mag Hytec or other? they add a gallon of fluid capacity, and have deep fins inside and out. They are supposed to drop temps under load. experience?
Tags
150, 2003, 60l, 8000lb, coolant, expedition, f350, ford, high, overheating, power, reduced, temp, towing, trailer, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
