Is a 5.0L flywheel the same as a 5.8L flywheel - Ford Truck Enthusiasts Forums
Old 08-09-2011, 12:24 PM
RustyBarnard RustyBarnard is offline
RustyBarnard is starting off with a positive reputation.
I'm in the middle of swapping in a standard 5 speed transmission
(ZF-42) from a 1994 F250 into my 94 F150 5.0L (302) 4x4 that originally had a automatic (E40D)
My question is the flywheel from the 5.8L going to work with my 5.0L? It is a 164 tooth ring gear and externally balanced.
Old 08-09-2011, 12:38 PM
SCRebel's Avatar
SCRebel SCRebel is offline
SCRebel is starting off with a positive reputation.
I dont know for sure, but I think the 351 flywheel is different. The 4.9 and 5.0 use the same.
Old 08-09-2011, 01:23 PM
loudfords's Avatar
loudfords loudfords is online now
loudfords has a great reputation on FTE.loudfords has a great reputation on FTE.loudfords has a great reputation on FTE.loudfords has a great reputation on FTE.loudfords has a great reputation on FTE.
They are not the same, they are balanced differently. Plus the 93 up 351W had an 11.5" clutch, while the 300/302 used an 11" clutch.
Old 08-09-2011, 01:42 PM
mustangzrule mustangzrule is offline
mustangzrule is starting off with a positive reputation.
You have 28 oz vs 50 oz. Be careful of the years of each engine too. The bellhousing will also possibly be different and thus a different number of teeth. Ford does us all a disservice with the multiple flexplates they use. Try finding a 50 oz flexplate with 157 teeth to mate to a 1968 Mustang C4 trans..... Grrr.
Old 08-09-2011, 01:43 PM
And the bolt pattern of the torque converter varies. Check ALL your parameters.
This is the worst part of building a Ford.
Old 08-09-2011, 01:49 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
The 4.9L (300 I-6) M/T flywheel is not the same as a 5.0L (302). The 5.0L M/T flywheel is not the same as a 5.8L (351W).
E8TZ-6375-D .. 5.0L M/T Flywheel / Marked: E8TR-6375-AA
Applications: 1988/96 F150/250 & Bronco.
E0TZ-6375-A .. 4.9L M/T Flywheel / Marked: E0TR-BA
Applications: 1980/96 F100/350 & Bronco.
The only thing that is the same 4.9L/5.0L/5.8L is the 164T M/T flywheel ring gear (C5AZ-6384-D).
Old 08-09-2011, 01:58 PM
Beanscoot Beanscoot is offline
Beanscoot is gaining momentum as a positive member of FTE.Beanscoot is gaining momentum as a positive member of FTE.
Flywheels and flexplates
The 300-6 flywheel and flexplate have no balance weights at all since it is an internally balanced engine.
Some 300 units are identical otherwise with some V8 pieces that have the same diameter, tooth count and use the same clutch.
Old 08-09-2011, 02:17 PM
SCRebel's Avatar
Now that I think about it, the flywheels are different. I did a 4.9 to 5.0 swap once, years ago. However I believe I used the 4.9 pressure plate and clutch. And I do believe I got another flywheel for the 5.0.
Old 08-09-2011, 02:39 PM
OK this is good help, My 5.8L flywheel is marked E8TR-BA don't think this is the part number of it is it?
I called Ford today and they said the flywheel is discontinued??
Should i just get one from napa? And What should i get? A 1994 F150 5.0L manual flywheel? or should i get a 1994 F250 5.0L manual flywheel?
As the ZF-42 5 speed was only offered in F250 and F350
On the centerforce web site sounds like the F150 ,F250, F350 all use the same clutch between 5.0L and 5.8L so i shouldn't mess that up right?
Old 08-09-2011, 04:40 PM
Alvin in AZ's Avatar
Alvin in AZ Alvin in AZ is offline
Alvin in AZ is gaining momentum as a positive member of FTE.Alvin in AZ is gaining momentum as a positive member of FTE.
www.rockauto.com
Ford
1994
F250
5.0L
Transmission-Manual
Flywheel
$44 to $104
...take your pick. ;)
Alvin in AZ
Old 08-09-2011, 05:09 PM
Quote:
No, it's an ID engineering number, not a Ford part number. Marked w/ID number: E8TR-6375-BA = Ford part number E8TZ-6375-C
Considering that the last MSRP was a horrid $457.77 (dealer net cost was bad enough @ $274.66), I doubt you woulda bought one if it was still available.
Did you see what I typed in post #6? It's the same tamale. 1988/96 F150/250 & Bronco 5.0L: E8TZ-6375-D
351W flywheel is not the same as a 5.0L The 5.0L flywheel is not the same as a 4.9L
Alvin in AZ (retired RR 'signal ape' and a well known raconteur on Ford truck websites) gave you a ref for rockauto.
Old 08-11-2016, 09:47 PM
BroncoBrian94 BroncoBrian94 is offline
BroncoBrian94 is starting off with a positive reputation.
4.9 will bolt to 5.0 but i think the 4.9 is internally balanced , where the 5.o is externally balanced. It will shake you out, DO NOT PUT 4.9 FLYWHEEL ON 5.0.
5.8 AOD swap q's fordboy97 1987 - 1996 F150 & Larger F-Series Trucks 9 10-21-2015 09:42 PM
5.0l to 5.8l swap balancing question CSJohnson 1987 - 1996 F150 & Larger F-Series Trucks 2 02-12-2014 10:31 PM
94 F150 E40D swap to ZF 5 speed swap questions RustyBarnard 1987 - 1996 F150 & Larger F-Series Trucks 4 08-07-2011 10:20 AM
5.0 vs 5.8 flywheel USAF FordGuy 1978 - 1996 Big Bronco 9 01-07-2010 02:02 PM
4.9 too 5.0/5.8 flywheel swap jonathan89 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 12-09-2005 07:14 AM
Tags
1994, 351w, 50, 50l, 58, 58l, 94, 96, balancer, f150, flywheel, ford, length, liter, transmission, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
