Motor Oil for Fuel Lube
You better not. You might get fined. Gone are the days you can simply drain your oil on the pavement.
I think I may have miscommunicated when I said he used recycled oil. What I am talking about is oil that has been re-refined. It sells for less than virgin oil and that is what he uses. From what I am reading, I am guessing that it does do some good. There are oils that may be better, but clean motor oil is better than nothing.
Used motor oil and/or used ATF for fuel.
I have friends, who happen to work at a diesel shop, who run straight used oil and ATF, they do filter it down to 2 microns and are careful about water separation, they do have extra filtration and water separators mounted on the bulk tanks in the bed of the trucks. During the summer down here it is just fine according to them, yes it smokes a little bit more, one of them is a 12 valve Cummins, the others are running 7.3, and 6.0 trucks and excursions. The way they explained it is, they had been running it for over 2 years with no problems other then changing fuel filters at 5k miles. ( By the way they have ran through emissions on ATF and passed, I have seen one guy run 14 sec quarters in his Excursion on straight used ATF. so it does run and pretty good too.)
How much do you spend on diesel every year, I am betting that is more then enough to replace a set of Injectors or even a motor, I was thinking of running used ATF in my 24 valve cummins as I have a bulk tank and pump on it already and can get used ATF without too much problem.
I asked him about it ruining my injection pump since it runs 1600 to r&r usually, he said if I ran straight ATF or used oil for only one year i would have saved more then enough on fuel costs to replace it like 3 times, not that I would need to. That is if I ran 25K miles like I usually do.
I have not done it yet, but if the economy keeps going downhill like it has been, I am glad I have 2 "alternative fuel" vehicles.
ATF/WMO will work as an alternative fuel...no questioning that. One thing it does not do is add any additional lubrication to the injectors/ fuel system.
It is considered insignificant on how it affects the lubricity. You are better to stay with methods towards the top of the list.
I noticed the chart does address waste motor oil, but not fresh motor oil. As I stated, the gentleman I know uses fresh motor oil and has had great results with it. I can see where used oil may have some problems associated with its use.
I finally ran through the tank of fuel treated with Lucas oil additive, and now I am trying the fresh motor oil alternative with a guart of Pennzoil 10W30 that I had lying around that I did not use in my '94 F150. After about 50 miles or so it is running smooth as silk. (As smooth as anyone can expect from an International diesel). I'll probably use this method until this half case runs out and then I'll try the Wal-Mart 2-stroke oil and see how it goes.
#29
