Whining noise !!! Transmission? - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 08-09-2011, 09:03 AM
tookey71 tookey71 is offline
tookey71 is starting off with a positive reputation.
OK Guys I need help,
I have a 1999 Navigator ( AWD) . It has a whining sound when the truck is in " Park or " Neutral " as soon as you put the truck in gear ( Reverse or forward ) the noise goes away. The noise increases with engine RPM's. The whining sounds like it is coming from underneath the truck. Please HELP ME!!!!!
Old 08-09-2011, 09:16 AM
SCRebel's Avatar
SCRebel SCRebel is offline
SCRebel is starting off with a positive reputation.
Have you checked the fuild in the trans? Or in the power steering pump?
Old 08-09-2011, 02:22 PM
I did check the power steering pump, but did not check the trans. mission fluid. I will do this A.S.A.P. Thanks For Your Response!!!!
Old 08-09-2011, 02:53 PM
SCRebel's Avatar
When you check the fluid, it should be a red color. And smell it. If it sells burnt, and or is a brown color you need to service your trans, and it could already be too late.
Old 08-10-2011, 05:50 AM
I checked the transmission fluid and it looked and smelled fine. Any more thoughts? Power steering pump sounded good. After i drove the truck about 10 miles the noise stopped., but it will come back when truck is first started. ????????????????
Old 08-10-2011, 06:46 AM
5.4T's Avatar
5.4T 5.4T is offline
5.4T has a very good reputation on FTE.5.4T has a very good reputation on FTE.5.4T has a very good reputation on FTE.
have you check your belt, belt tensioner, my expedition used to make a squiky noise.
Old 08-10-2011, 08:52 AM
Checked the belt tensioer yesterday, it was fine. Today i may try to run it without the belt to eliminate the belt.
my 2016 6.2 is whining all the time PAracephan 1999 to 2016 Super Duty 10 05-18-2016 08:55 AM
Whining Noise Jackford1993 1987 - 1996 F150 & Larger F-Series Trucks 11 03-09-2014 05:12 PM
Whine/Whistle @ Idle OneTon4Fun 6.0L Power Stroke Diesel 4 12-01-2011 01:19 PM
Identifying Front Pump Whine vs. Power Steering Whine 5.4L to Freedom 1999 to 2016 Super Duty 4 12-16-2010 05:51 PM
1985 Ford F150: Whining sound blackjack28 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 07-10-2007 09:45 AM
Tags
03, 1999, 2000, 2001, 2007, expedition, ford, licoln, lincoln, loud, making, navagator, navigator, noise, trans, transmission, whining, whinning, wineing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
