94 F150 Electrical Problems - Ford Truck Enthusiasts Forums
Old 08-09-2011, 07:26 AM
mpmccarthy mpmccarthy is offline
mpmccarthy is starting off with a positive reputation.
I am working on a 94 F150 that drags the battery down, especially when it is running.
My friend was just cruising around when all of a sudden the truck started acting up (running rough, hesitating, etc.). She parked and then the truck wouldn't start. The next morning we returned to the truck and it started. However, on the trip home (about 4 miles) it started acting up again.
I checked the battery and it was at about 9 volts. Tried charging the battery and it only charged to 11.4 volts after a full day.
A fully charged, supposedly good battery, was installed. The truck started fine. I checked the voltage at the battery with the truck running and it was 14.5 Volts. Overnight, the battery ran down again. Obviouly something is draining the battery.
I recharged the battery and took a short trip to the store. A trip of about 30 minutes discharged the battery down to 9 volts. Of course the truck doesn't run very well when this happens.
When I recharged this battery it only charges to 11V.
My biggest fear is that something is eating batteries. The only thing I think would do that is if the alternator is overcharging them.
Has anyone had this problem or have any other ideas?
Passenger battery not charging. 99 7.3 bigbadbob17 1999 - 2003 7.3L Power Stroke Diesel 20 01-01-2015 11:23 PM
Voltage spike-regulator or battery?? phoneman91 1987 - 1996 F150 & Larger F-Series Trucks 2 05-06-2010 05:22 PM
Help: Fuel Relay Chattering & Battery drains at idle RichInTN Ford Inline Six, 200, 250, 4.9L / 300 15 09-06-2008 05:56 PM
Problem charging RV batteries hdway Electrical Systems/Wiring 1 11-11-2007 11:27 PM
f150 4.6 battery won't stay charged when running darrengj 1997 - 2003 F150 5 09-10-2007 08:03 PM
Tags
1994, 2003, 94, alternator, drag, electical, electrical, f150, ford, model, problem, problems, system, truck, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
