im just woundering cus the little things bother me and one of them little things is seeing oil spots on the ground. i cant seem to shake them everytime i replace orings the oil drops slow down but then something else starts to leak.
I've got 206K and have only had to replace one HPOP ring, the fuel drain valve, and the two on the valve cover's "doghouse".
Spotless driveway.
Pop
Ive got 138k and have only done the fuel drain valve.
Im with pop "Spotless Driveway" so it is possible.
Do like milwaukee1979f150 suggested and get her all cleaned up and start attacking the leaks.
If you do the work yourself it want cost much plus you will learn alot about your motor or at least the valley area. Its not a bad job, where are you located one of us may be close enough to give you a hand.
well so far with 138,000 miles i did turbo once now again,ebvp complete rebuild, camshft sensor oring, whole fuel bowl,ccv and now the 3 hpop ones. i know my rear main is leaking or the pan seal right there but i have oil mist on top side to make dirt and oil sludge on everything , barely any pooling in valley and front leak now appears the lpop seal
and thats me driving like its a brand new lincoln, i seriously baby my truck and all my buds 7.3's they treat like crap and they leak less or just a much and i can figure it out
WOW Seth does your truck a have a dip pan/bucket to keep it off the ground? Just kidding I have had my share of leaks but I always fixed it pretty easy.
