Starter, solenoid, or ground issue? - Ford Truck Enthusiasts Forums
Old 08-08-2011, 09:36 PM
dbuck50 dbuck50 is offline
dbuck50 is starting off with a positive reputation.
my truck sometimes starts fine. The often when it hasn't been started for the day, it doesn't. I turn the key, can hear the fuel pump pressurize and hear a loud click...like a solenoid. I turn the key back and forth several times, it keeps doing it and eventually it will turnover and run fine.
I had the same problem a couple years ago and replaced the starter and it seemed to go away for a while, but slowly started back again. Could it be the starter again? I have a feeling it might be something else, like a grounding issue or I think there are two solenoids? any ideas?
Old 08-08-2011, 11:28 PM
hoss khaos's Avatar
hoss khaos hoss khaos is offline
hoss khaos is starting off with a positive reputation.
I would check the wire that runs from the solenoid to the starter. If it has corrosion on it, it'll do that. My truck does that too sometimes. If the starter operates how it always did (meaning normal speed and sound) when it actually decides to turn over, I'd think it's ok. If it's sluggish, it might be bad. But check that cable and even the other battery cables for a loose or dirty connection. Sometimes a solenoid can do that too
Old 08-09-2011, 05:43 AM
ArdWrknTrk ArdWrknTrk is online now
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
Check the neutral safety switch or clutch interlock.
You may just be hearing the fuel pump relay.
Old 08-09-2011, 07:30 PM
tjc transport's Avatar
tjc transport tjc transport is online now
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
check if there is a small wire going to the solenoid on the starter. the connection there is a known problem, and will cause the very issues you are describing.
but a bad starter, bad fender mount starter relay, and bad cable connections will also.
Old 09-01-2011, 10:43 PM
is there a way to fix the wire/connection? it is a bit corroded...how to I make it a good connection again? it looks like it is permanently attached.
Old 09-03-2011, 02:45 AM
skaterbro's Avatar
skaterbro skaterbro is offline
skaterbro is starting off with a positive reputation.
Best thing to do would be to get a starter with the post style connection for the relay wire. That spade style connection is the problem as it's much more susceptible to corrosion.
You can try cleaning the connection but i'm sure that day will soon come again when you're sitting there turning the key back and forth waiting for it to catch.
Old 09-03-2011, 03:02 AM
muscletruck7379's Avatar
muscletruck7379 muscletruck7379 is offline
muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.
sounds like its most likely a connection issue. you don't have those 99 cent battery cable connectors do you?
Old 09-03-2011, 05:35 AM
pedant
Clean up the spade connection really good and pack it full of dielectric silicone before plugging it back in.
It will help keep the water out.
Old 10-16-2011, 09:53 PM
OK, the issue continues. I cleaned up the spade connection...even replaced the spade connector and it is still doing the same thing. Checked the voltages with a meter and I have 12 Volts at the starter, but with the key turned to the starter position (where it would normally turn over) I have nothing at the spade connection...I would think it should be 12 volts when the key is turned all the way to start. The fendrer mounted relay is clicking when the key is turned.
Does anyone know where the signal to the spade comes from? is it the relay? or maybe the ignition switch? I think whatever it is might be the problem.
again, if I turn it back and forth enough time, it will eventually engage the starter and startup.
Old 10-16-2011, 09:59 PM
hoss khaos's Avatar
Either the starter solenoid or the cable from the solenoid to the starter.
Old 10-16-2011, 10:11 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is online now
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
I just replaced the solenoid on the inner fender of my 93 T-bird Friday, it was acting exactly the way you describe..
It would clunk every time you turned the key to the start position, but nothing happened. Checked voltage out of the solenoid to the starter, with the key in start position, you guessed it NUTTIN' Changed it out and it hasn't missed a lick since..
Hardest part of the job was finding a solenoid NOT made in China!!!!!!!
Old 10-17-2011, 05:14 AM
pedant
Quote:
And how did you do that?
Old 10-17-2011, 09:27 AM
Thanks!...I just looked online for a new fender mounted solenoid...looks like the china ones have real bad reviews. I ordered a motorcraft one...so hopefully it will be of good quality.
thanks everyone. I'll post the results once installed for the benefit of others.
Old 10-24-2011, 08:30 PM
sure enough...the starter solenoid on the fenderwall was the culprit. I bought a motorcraft OEM replacement (from Rockauto) and the problem is now gone...thanks everyone.
Old 10-24-2011, 08:44 PM
blkF250HD's Avatar
blkF250HD blkF250HD is offline
blkF250HD is gaining momentum as a positive member of FTE.blkF250HD is gaining momentum as a positive member of FTE.
Glad to hear it's fixed. One other thing to keep in mind for the future: check the ground cable connection to the engine block. We had in a 95 E150 5.8L and it was kicking the tech's ***. Put a battery in, a starter, a solenoid, still had a constant click at the starter. Another tech looked around and noticed some corrosion around the ground cable terminal, along with the bolt being loose. On this particular vehicle the cable connects to the block on a pad below the air pump.
Starter solenoid - signal wire wufnu 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 10-19-2015 06:26 AM
1980 F100 turn key, won't start then everything dies. Uncle Paul 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 05-22-2014 10:33 AM
I need a better hot in start wire.. nothercrash 1973 - 1979 F-100 & Larger F-Series Trucks 9 03-10-2014 09:57 PM
Starter gone haywire bigfix 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 01-01-2012 06:39 PM
starter problems thumper869 1994.5 - 1997 7.3L Power Stroke Diesel 3 10-27-2009 02:17 AM
Tags
351w, 68, 87, connections, dirty, f150, f250, f350, ford, ground, grounding, issues, relay, soleniod, solenoid, starter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
