Suggested Guages for 2012 F250 6.7
Thanks for the info on the EGRs. Was gone this weekend at brother-in-law's funeral so this is the first chance to reply. So how many degrees do you add to the EGR 1 reading to get a more accurate EGR temp?
Painted Horse has mentioned he would rather not see 1,200 on EGT11 but I don't know what the computer is programmed as a high temp limit before defueling.
For oil temp Ford CS has said near 260 is considered excessive.
Edge posted they released the 2011 firmware (not sure what date).
Edge Products| What's Happening
Ambient Air Temp, Accel Pedal Position, Barometric Pressure, Battery Voltage, Corrected Speed, Dist. Between Regens, Dist. Since DTC Clear, Dist. Since Regen, DPF Pressure, DPF Soot Mass, DTC Count, EGT Post DPF, EGT Pre DPF, EGT Post Turbo, EGT Post SCR/Pre DPF, Engine Coolant Temp, Engine Load, Engine Oil Temp, Engine RPM, Engine Run Time, Fuel Level, Fuel Rate, Gear with Reverse, Gear with TCL, Intake Air Temp, Manifold Abs Pressure, Mileage Coach, MPG Instant, MPG Average, Nox PPM, Regeneration Status, Reductant (Urea) Level, Time 0-60, Time 1/4 mile, Torque, Torque Solenoid Pressure, Trans Temp, Turbo Boost
I have the Insight CTS (had it on my '10, and they just released the software updates for the '11), and had a few observations while towing home from Bristol to MD on 81. EGTs are around 800 and Oil temp around 200. When regen kicks in, EGTs go to 1200-1300 and oil tem goes to 220. Seems like alot of stress on the system. Regen kicked in twice in 7 hours of driving. I like the R message on the CTS letting you know its full duration.
A tuning module isn't getting near my truck anytime soon, if at all.
This device only receives information from the truck computer modules.
I have not researched the tuning parts of this but my understanding is you buy additional modules that will then communicate to the Edge (maybe with different firmware?) to allow you to change your power levels which will void the warranty but that's only a guess on how that process works.
2011, 2012, 250, 67, antifreeze, date, diesel, f250, ford, fordcom2012, gauges, navigation, release, specs, type
