'56 Frame Build with Crown Vic front end - Page 2 - Ford Truck Enthusiasts Forums
Old 02-05-2012, 02:16 PM
5pntslw's Avatar
5pntslw 5pntslw is offline
5pntslw is starting off with a positive reputation.
What year Crown Vic front end is that? It looks a little different then the ones ive seen...
Old 02-05-2012, 07:15 PM
CTom's Avatar
CTom CTom is offline
CTom is starting off with a positive reputation.
Quote:
Originally Posted by 4mrdragoon View Post
It looks great guys, I have a ton of questions. what year Crown Vic did you use? What are you putting in it for a motor? What are the plans for the steering this was causing me some issues during my mock up. Great work and keep the pictures and info coming.
Merry Christmas
Thanks guys........'03 and up CV should all be the same, I believe this is an '03 front end. We have installed a 460 Ford motor, what else?? The steering is giving us a little problem because of the headers and the narrowing of the frame. I will try and get some pictures this week.............
Old 02-05-2012, 07:22 PM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
Quote:
Originally Posted by CTom View Post
I thought this was kinda cool...........The roof was pretty well peppered with rot so we made a "buck" out of it, then made a mold and next made a new roof from fiberglass. Came out pretty good.....
That replacement roof could make u some money!
Sam
Old 02-06-2012, 12:07 AM
5pntslw's Avatar
The front end just looks different then the ones i've seen on the 03-07... They bolt flat on the top of the frame where as this one you have pictured does not, instead it looks like it has two brackets that are welded to the frame and bolt to the sides of the front end.. I've been looking around and it appears it may be the 08 and up crown vic front end. I was just curious because it looks cleaner then the other style. I wonder if its the same width as the 03-07 If so I'd like to find one of them instead lol btw that truck frame is what I dream mine would look like.. That thing is pretty, y'all are doing some great work
Old 02-08-2012, 05:00 PM
CTom's Avatar
Quote:
The front end is from a 2004 CV. We replaced the stock Ford mounts. Instead of mounting the crossmember to the frame with long bolts like the factory did, we bolted it from the bottom for a cleaner look.
Old 02-08-2012, 06:56 PM
5pntslw's Avatar
Ok I gotcha.. It does look alot better that way. Y'all have done done awesome work on it!
Old 02-08-2012, 08:12 PM
fordman75 fordman75 is offline
fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.
It's got an 8 inch rear...........
Very nice work!
Just wanted to let you know that isn't a 8" rear. That's the 8.8".
The 8" is a smaller version of the 9" with the drop out center section.
Old 02-08-2012, 08:47 PM
4mrdragoon's Avatar
4mrdragoon 4mrdragoon is offline
4mrdragoon is starting off with a positive reputation.
Looks great, I keep checking this out and seeing what changes I could make to mine. Such as the engine mounts, steering and lower A arm mounts. Keep the pictures and info coming this swap is gaining a lot of interest
Old 02-11-2012, 08:48 AM
CTom's Avatar
Quote:
Originally Posted by fordman75 View Post
Very nice work!
Very right FordMan, we usually work with the Ford nine inch but the owner wanted rear discs. There is a guy nearby that builds rears for the Mustang crowd and he did this one, all we did was narrow it a little.
We are building this truck at our non-automotive shop. The owner of our company owns the truck and is doing most of the construction on it, My brother and I built the frame and rolling chassis.
Old 05-11-2012, 10:59 AM
CTom's Avatar
Steering Rack
Here is how we cut the steering rack.......I have had lots of intrest in this.
This picture shows how much we moved the "piston" on the rack.
This hole needs to be filled.
Old 05-11-2012, 01:49 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
Curiosity question: Since it required so much complex work to install, narrowed frame, crossmember, rack, etc., and it is not notable for handling geometry, what was the compelling reason for using the CV IFS?
Old 05-11-2012, 01:51 PM
AXracer's Avatar
Quote:
Sam
Mid Fifty sells a FG roof.
  #28
Old 05-12-2012, 02:12 PM
CTom's Avatar
Quote:
Best reason in the world..........my boss paid me to do it!
  #29
Old 09-16-2012, 08:40 AM
62Duece 62Duece is offline
62Duece is starting off with a positive reputation.
Any progress on the truck? I'm sure 100's of people here that are interested in the CV suspension, but like the width of it would love to see a step by step w/pics of narrowing the steering rack. I am/was considering narrowing the crossmember to match the pivots on a Fox/sn95 rack but that's 6"
  #30
Old 06-18-2014, 12:33 AM
Richard Daugird Richard Daugird is offline
Richard Daugird is starting off with a positive reputation.
I know this is an old thread but I'd like more info as well.
Soot and Oil Near Turbo - where to start tjmike 1999 - 2003 7.3L Power Stroke Diesel 6 05-20-2014 11:51 AM
Love some suggestions. 1952 ford f3 build. Mattie2294 1948 - 1956 F1, F100 & Larger F-Series Trucks 38 05-30-2013 01:05 PM
F550 Build Diesel_Brad 1999 to 2016 Super Duty 92 06-12-2012 12:55 AM
Post a pic of yourself to put a face with a name. 98SVTCobra 1999 - 2003 7.3L Power Stroke Diesel 543 01-23-2010 10:09 PM
First Spring Clean up. Smokefan420 Canadian National Chapter 24 04-04-2007 01:40 PM
Tags
1956, 1960, axle, clip, crown, end, f100, ford, frame, front, pickup, swap, truck, vic, victoria
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
