i think im in love
i think im in love
2320 - Trucks & Truck Tractors, Wheeled at Government Liquidation
i want this i wonder if it has a idi
Received 3,099 Likes
on
I beg to differ, if you look at the engine pic of the paystar, you can see 4 injector lines behind the compressor. A cummins of that year would be a small cam (77 was the last year for them), and they all had the PT system with injectors fired by the cam so there is no external injector lines
on
on
look at the engine pic of the paystar. you can see three of the injector lines behind the power steering reservoir. that is either a 210 or a 250 cummins.
come to think of it, as a military vehicle it would most likely be the 210, and a civilian vehicle would have the 250
on
how about this one Joe??
Your VIN number: 1FTJW36M9REA15238
World Manufacturer Identifier - 1st, 2nd, 3rd Positions:
Manufacturer: Ford Motor Company, USA
Make: Ford
Vehicle Type: Truck (Completed Vehicle)
Brake Type and GVWR Class - 4th Position:
Brake System: • Hydraulic brake system, Class H, GVWR 9,001-10,000 pounds, None
Line Series, Chassis Type, Body Type - 5th, 6th, 7th Positions:
Line Series: F-Series - F350
Chassis Type: 4x4
Body Type: Crew Cab
Engine Type - 8th Position:
Engine: 7.3(445cid)
Cylinders: V-8
Fuel Type: Diesel
Horse Power: TBD
Model Year - 10th Position:
Model Year: 1994
Assembly Plant - 11th Position:
Assembly Plant: Kentucky Truck: Jefferson County, Kentucky
Make: Ford
Chassis Type: 4x4
Body Type: Crew Cab
Engine: 7.3(445cid)
Cylinders: V-8
Fuel Type: Diesel
Horse Power: TBD
Model Year: 1994
