Brake issues! Vacuum pump problem? - Ford Truck Enthusiasts Forums
Old 08-08-2011, 03:43 PM
LSO1123 LSO1123 is offline
LSO1123 is gaining momentum as a positive member of FTE.
The left front brake caliper was siezed up on my truck. Both calipers looked pretty rough so I replaced both of them and put new pads on. Now the left one seems like it's sticking a little again. Also alot of times my brake pedal feels like trying to mash a concrete block for a few seconds then it softens up. I bled the brakes until no bubbles were coming out when I put the new calipers on. The hard pedal issue was there before I installed the new calipers. Could this be a vacuum pump problem? The pully on the vacuum pump looks pretty rough, looks like rust and a lot of gunk on it, I was thinking of taking it off and cleaning it up to see it that helped any. Thoughts?
Old 08-08-2011, 06:47 PM
greywynd greywynd is offline
greywynd is starting off with a positive reputation.
Sounds like it could be vacuum, or a booster issue. Pull a vacuum line off and see how hard it grabs your finger when you stick it on the end, it should have a definite suction.
Another thought, you could try pulling the vacuum line off the booster, and stepping on the brake pedal to see if it feels any different too, might give you another indication.
Old 08-08-2011, 08:53 PM
Okay, I'll try those. As far as one caliper feeling like it's sticking, I figured that out. It seems that if you put a brake pad on backwards to where the metal side of the pad is contacting the rotor, they don't work very well! I'm such an idiot!
Old 08-08-2011, 09:06 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
Ummm? ouch for the rotor? Did it damage it to much?
Old 08-08-2011, 09:09 PM
It's probably gonna need replaced but it has to work long enough for me to drive it to autozone tomorrow to get a new one! That's what happens when I try to work on something while watching thee kids!
Uneven brake pad wear issue Blakshukvw Excursion - King of SUVs 11 12-30-2016 05:51 PM
2003 Brake Caliper Sticking daveplot 1997-2006 Expedition & Navigator 6 08-21-2015 05:46 AM
Having a STICKY time with my Brakes!! Restlesswildman 6.0L Power Stroke Diesel 15 06-18-2014 07:19 PM
1990 F150 both brake dash lights on vaughandw Brakes, Steering, Suspension, Tires, & Wheels 14 10-14-2013 10:26 PM
hard brake pedal LSO1123 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 20 11-28-2012 08:22 AM
Tags
1991, 1996, e350, f350, ford, problems, pump, pumps, ranger, recall, truck, vaccum, vaccuum, vacum, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
