7.3 to 6.9 heads
Old 08-08-2011, 07:40 PM
86f250XLT-4x4's Avatar
86f250XLT-4x4
86f250XLT-4x4 is offline
7.3 to 6.9 heads
Ok here is what's going on I have a 6.9 that I pulled out of the truck and is in waiting for rebuild the one of the heads might be junk I am buying almost ready to drop in 7.3 I have read that the 7.3 heads have a few differences. I ask because when I am almost finished rebuilding the 6.9 will the heads off the 7.3 work? I plan on putting arp head stud kit on the rebuilt 6.9 because I plan on putting a hypermax turbo kit on it
Old 08-08-2011, 08:07 PM
greywynd's Avatar
greywynd
greywynd is offline
6.9's use 7/16" head bolts, and 7.3's use 1/2". Makes it hard to swap heads. I seem to recall there being some differences in coolant passages too.
Old 08-08-2011, 08:37 PM
86f250XLT-4x4
How different is the coolant passages? I think the head bolt holes in the 6.9 block can be enlarged
Old 08-08-2011, 09:06 PM
farmert's Avatar
farmert
farmert is offline
The thread pitch is different, so enlargeing the 6.9 to the 7.3 1/2 inch head bolt won't work.
Old 08-08-2011, 09:10 PM
hairyboxnoogle's Avatar
hairyboxnoogle
hairyboxnoogle is offline
I recall someone looking into see if 9/16" studs would work, not sure what the result was. General consensus was there would be too much cylinder deflection.
Old 08-08-2011, 09:21 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
If you are "rebuilding" the 6.9 why even think about 7.3 heads?? That is part of rebuilding you have the heads done! Or am I missing something?? IDI's cost to much money to rebuild so if you are going to only do it halfway just stop and save your money you will end up having to just redo it again and cost double the money later.
Old 08-08-2011, 09:29 PM
86f250XLT-4x4
No it's getting a full rebuild I think one of the 6.9 heads are junk it had 3 burnt valves and a small crack next to the pre chamber I was just hoping I would be able to get the 7.3 heads redone when I finished the rebuild and stick them on if the 6.9 head is actually bad
Old 08-08-2011, 09:32 PM
ford390gashog
You can get pretty nice fully redone 6.9 heads for (last time I checked) for 224.00 each shipped!!
264WSM
08-31-2014 10:23 PM
Mikey Oldaker
06-03-2012 12:48 AM
topgunn
22
10-29-2009 05:55 PM
muddin07
21
05-06-2009 06:24 PM
david51
06-17-2001 08:33 PM
Quick Reply: 7.3 to 6.9 heads
