Flat Towing Superduty Anyone?
I have recently purchased a 2011 F250 4x4 Lariat and I am considering getting a motorhome. I didn't know I would be getting a motorhome but now I am required to travel for my business more than expected and I want to pull my Superduty behind it, preferably without a dolly or trailer.
Can I flat tow a 4x4 automatic or what is involved? Do I need to disconnect the driveshafts? I know it will be better to just put it on a trailer but I'd like to avoid having a trailer when I disconnect.
I have towed an old suburban and jeep behind my coaches before but they didn't have electronic transfer cases so I'm not sure I can "put it in neutral" with the Superduty's 4x4 system. BTW my coach has a Caterpillar C-15 engine (625 horse) so i'm confident it can pull the truck with no problems. Thanks!
Trailers in Texas over 4-5k (definately by the 7k mark) are required to have brakes. I don't know anything about what the laws are involving a vehicle in tow versus a trailer, but a 4wd SD is a heavy peice of steel to be towing around and being left to it's own accord.
I don't know how tough your RV is (as in, does it have a pintle hook/2.5" receiver, I've seen some coaches with some HUGE enclosed trailers), but equipment trailers aren't too expensive (relative to the cost of a SD), and you'd get brakes, maybe sway control, and you won't be burning the tires on the truck or having to reinstall driveshafts everytime you want to drive it.
Most owner's manuals address this issue. Here's your link http://www.motorhomemagazine.com/Din...-Towing-Guide/
Steve
Steve
I think you want this document:
http://www.motorcraftservice.com/vdi...g%20Manual.pdf
See page 39.
If you had a manual transfer case, you could tow 4-down. With ESOF, you cannot. Which means you will need a driveshaft disconnect system to make doing this practical on a frequent basis.
See page 39.
Thanks everyone for the replies.
I would rather have a motorhome type vehicle because of the pass through in bad weather and convenience of being able to have my wife do things in the coach when it's safe (while driving).
I have a feeling I will put it on a flatbed so that I can have the advantage of trailer brakes, not wearing out tires, etc. as aforementioned. I appreciate all the solid advice given.
POWER STEERING PUMP
I HAVE BEEN TOWING MY 1999 F250 4X4 STANDARD DIESEL FOR A COUPLE OF YEARS NOW. NO DRIVE TRAIN PROBLEMS. BUT, I THINK I AM BURNING UP POWER STEERING PUMPS. NOT SURE THIS IS THE PROBLEM OR IF I AM JUST GETTING BAD PUMPS. NOW ON THIRD ONE IN THREE YEARS. DOES ANYONE HAVE ANY TECH INFO ON THIS?
Post your own thread regarding the power steering pumps.
Also, your CAPS LOCK is on.
Carhauler 14,000 Lb w/ 6" I-Beam Frame Load Trail Trailer Manufacturing
When it comes to towing, overkill is underrated. Have too much trailer rather than not enough. Your Cat engine will handle it with power to spare.
