98 E150 4.6 temp sensor
Old 08-08-2011, 12:28 PM
walkingevildead's Avatar
walkingevildead
walkingevildead is offline
Hi guys,
New here but I have a question already. My 98 E150 with 4.6 v8 has a problem with the AC on the temp gauge goes to overheat after about 15 min but now with no AC on I can drive it cross country and the gauge never moves out of the normal range. So I changed the thermostat flushed the system and put all new coolant back in and I still get the same problem. I took it to a Ford garage and they told me it was the sensor for the gauge was not working right and said the sensor was around $30 but labor was going to be around $600 and said it was a major task to change. Does this sound right? where is this sensor located on a 4.6? Any pictures would be a help!
Old 10-25-2014, 11:05 AM
Amberrenee's Avatar
Amberrenee
Amberrenee is offline
coolant temp sensor
Hi, i have same question. I have a 98e150 4.6 triton. Did u ever find where the sensor is located. I found one on passenger side in front, left of alt. But i was told that one only controls gauge and the one that send signal to computer is elsewhere.is that correct. I seen one under intake manifold toward front but was told that one only measured block temp. Can u help me with location please. I posted but am not getting any answers
Old 10-26-2014, 07:00 AM
JWA's Avatar
JWA
JWA is online now
Received 1,393 Likes on 1,102 Posts
The two of you should post these same questions in the Modular Motor forums here on FTE--we have a V8 section.
Because these are common parts someone there has had this same issue and almost certainly done their own repairs.
HTH
Old 10-26-2014, 12:05 PM
Amberrenee's Avatar
Amberrenee
I figured he could answer since his post wad from 2 yrs ago. Thank
coonhntr15
Modular V8 (4.6L, 5.4L)
03-23-2015 05:45 PM
mikeeeep
05-05-2009 07:34 PM
Klahr_R
1997 - 2003 F150
08-18-2008 02:22 PM
Sharpshooter77
09-16-2007 06:37 AM
Quick Reply: 98 E150 4.6 temp sensor
