Fel-Pro vs. Victor Reinz vs. OEM Gasket Quality . . . - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 08-08-2011, 11:08 AM
JoeVR5's Avatar
JoeVR5 JoeVR5 is offline
JoeVR5 is starting off with a positive reputation.
Hey guys,
I have been reading a lot of posts on this topic, mainly the most recent one about the Lower intake Manifold Gasket Replacement, and I wanted to break off a new thread to ask a specific question about gaskets . . .
From talking to a couple of other guys, they said that Fel-Pro was designed BETTER than OEM and no longer has any cork in it.
However, from reading online, it seems that OEM is definitely still the way to go and that Fel-Pro is inferior.
I am doing my intake system and was wondering about different gasket manufacturers . . .
(1997 Ranger -- 4.0L V6)
OEM
Fel-Pro
Victor Reinz
On RockAuto.com, a complete Fel-Pro set is $68 and the Victor Reinz gaskets are $71. I'm putting in a big order with RockAuto, so I was thinking of ordering a set of Victor Reinz manifold gaskets.
Can anyone give me their thoughts on this?
Thanks!
Joe
Old 08-08-2011, 12:20 PM
Lead Head Lead Head is offline
Lead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to all
Never had a single problem with a Fel-Pro gasket.
Old 08-08-2011, 04:13 PM
JoeVR5's Avatar
That's what I've heard as well . . . However, the thread that talks about the Lower Intake Manifold Gasket replacement advises against Fel-Pro . . . but it was originally posted 7 years ago, so I thought that maybe they had improved their gasket design.
The Fel-Pro complete Intake Gasket set is $68 on Rockledge. I'm thinking about going that route
Old 08-09-2011, 10:07 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.
The lower gasket as a Fel-Pro is fine. They are easier to install than the OEM gasket, but the OEM gasket is better. I would go so far as to advise against either. The upper intake gasket however, OEM is definitely the way to go, particularly if you have the plastic intake manifold. The OEM is redesigned to correct a design fault, the FEL-PRO is more similar to the original faulty design.
The Victor Reinz are most likely rebranded repacked Fel-Pro gaskets.
Victor Reinz or Fel-Pro gaskets. 03excab Modular V8 (4.6L, 5.4L) 1 03-22-2016 03:11 PM
BEST gasket vs. FEL-PRO gasket 1964FORDTUF 1961 - 1966 F-100 & Larger F-Series Trucks 3 07-12-2015 06:16 PM
Chevy Donut gaskets for my Uppipes Neal 97 250 1994.5 - 1997 7.3L Power Stroke Diesel 15 05-04-2012 12:01 PM
Fel-pro gaskets pclayton FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 10 01-05-2012 06:27 PM
OEM head gaskets VS. Black Onyx VS Victor Reinz gaskets? JBSIXGUNS 6.0L Power Stroke Diesel 6 12-07-2010 08:36 AM
Tags
60, e4od, f150, felpro, ford, gasket, gaskets, manifold, oem, pan, ranger, reinz, trnsmission, victor, vr2000
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
