6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
$$ truck in shop $$
Old 08-08-2011, 07:16 AM
Gwilkrrs's Avatar
Gwilkrrs
Gwilkrrs is online now
$$ truck in shop $$
sounds expensive.... 08 leveled with 62k miles needs-
drag links, 1 tie rod, trac bar ball joint, stabilizer shock shocks.
rad is also leaking from hose..... looking into coverage.....
also looking into exhaust leak from up pipe.....
this explains the death wobble, but at 62k miles? damn.
Old 08-08-2011, 07:37 AM
Texas450's Avatar
Texas450
Texas450 is offline
All the front end work will cost around 900....at least that's what they qouted me....I went some where else for have the cost
Old 08-08-2011, 08:50 AM
senix's Avatar
senix
senix is offline
Received 1,415 Likes on 1,010 Posts
Hmmm, should not need to be fixed like that. Power train is to 60K, maybe they will go ahead and cover it.
I am replacing my tie rods too, but for a different reason. I bent one.
Old 08-09-2011, 06:26 AM
Gwilkrrs's Avatar
Gwilkrrs
my dealers answer on my front end warranty was coverage for 60.1 and i am too far out to justify the help.
he also said he was going to the boss to try to cover the lower rad hose leak but i was out of warranty on the tsb also. i dont think they are trying to hard to help........
hoping the exhaust up pipe leak will be covered under the emmissions or the esp exteneded......... but they havent even gotten that far.....
Old 08-09-2011, 06:36 AM
Maxium4x4's Avatar
Maxium4x4
Maxium4x4 is offline
Received 3,392 Likes on 2,089 Posts
2K miles is far out.... sounds like he is not very motivated to help out.
Old 08-09-2011, 07:05 AM
senix's Avatar
senix
senix is offline
I am thinking a call into ford cust svc may help. Sell it to them as a good will gesture. After all it did not happen in just the last 2K miles.
Old 08-09-2011, 07:08 AM
Maxium4x4's Avatar
Maxium4x4
I would tell them you have had the death wobble for over a year and just got back from Alaska...
c04678
6.7L Power Stroke Diesel
02-07-2017 07:36 AM
r-man
02-22-2009 06:37 PM
liftedgrocerygetter
74
10-21-2008 07:34 PM
skipppy75
07-02-2008 12:59 PM
kjg26
12-19-2006 10:42 PM
Quick Reply: $$ truck in shop $$
