F6TU-8275-DA?
F6TU-8275-DA?
So I've been looking for a new hanger/sending unit assm. for my '96 F350 (7.3l, E4OD, 4x4, 133" WB, reg Cab, Straight up pick up). It is just the hanger with the sender, wires, float, etc.. There is no pump in the tank for this unit. I pulled the part number off, F6TU-8275-DA, but after searching Rock Auto, NPD, LMC, Ford's parts sites, local stores, I can't even come up with the number. It's like this part never existed.. Any ideas? All my local junkyards have nothing as well.... Stumped! Thanks!!
Steve
Steve
First off you have missed read the drawing number on the part.
It is F6TU-9275-DA but you do not want the drawing number you want the part number that is F6TZ-9275-DA.
Here is one on ebay:
95-98 FORD F-SERIES DIESEL FUEL SENDER F6TZ9275DA OEM | eBay
A Few Corrections
So I called up a different Ford dealership than I usually do, only to discover that my number wasn't the one used by Ford. The correct number is F6TZ9275DA, which I found plenty of info on but I can't find one for under $275. Most places don't sell them anymore or went out of business. Help! Thanks guys!
Steve
Steve
Naymlis
01-15-2016 08:51 AM
seth1
12-05-2010 11:07 AM
bobpat204
01-07-2007 12:53 PM
1997, 58uf9275da, 9275, assembly, codes, diesel, f350, f6tu, f6tu9275, f6tu927508, f6tu9275ca, f6tz9275ca, ford, fuel, pump, sender
