I have a 97 350 that im looking for a new rad support. I cant seem to find a part number for one that works with ac. The only one I found was F4TZ-16138-A but researching this number says without ac. Anybody have a number or some info that may help. Thanks
I just went thru the same thing this past fall. Ended up buying one for a gasser and cutting it up, used parts from new and old to make a new one. The gasser support had a smaller hole. It wasnt too difficult to make one. If you have a parts store that will order one and send it back if it wont work, get the non ac diesel one and modifiy it. I think it will be alot closer to working than the gasser one.
I just went through this problem. Ended up just fanning up my own. 45 dollars in metal and rubber and you can hardly tell it's not stock! Easy to do on your own if you can make a few good tack welds.
