'97 Ford Explorer XLT - Not starting
Old 08-07-2011, 10:39 PM
Jaxom's Avatar
Jaxom
Jaxom is offline
Unhappy '97 Ford Explorer XLT - Not starting
4.0 Liter, SOHC, VIN E.
Replaced engine for a friend. Everything is hooked up. Turn the key: Dashboard lights light up, fuel pump does not turn on, starter will not engage with key. Starter will work if you jump the silenoid. Not getting fuel or spark.
Vehicle has sat for about a year and half before the engine was replaced.
Engine was replaced due to the timing chains failing.
Anyone have any suggestions on what the issue could be?
Thanks!
Old 08-07-2011, 11:39 PM
aquanaut20's Avatar
aquanaut20
aquanaut20 is offline
Thanks!
Check all main cables connected to the battery, then main fuses/fusible links... Philip
Old 08-08-2011, 12:49 AM
Jaxom's Avatar
Jaxom
Jaxom is offline
All fuses and relays are good. Checked with an ohm meter, same with fusible links. All are good.
Old 08-08-2011, 06:32 AM
shorod's Avatar
shorod
shorod is offline
Try shifting to Neutral and see if it will start. Maybe the Transmission Range Sensor (TRS) is faulty. Also confirm that the TRS was connected properly when the engine was installed. Does it make any sort of clicking when the key is turned to the Start position? If so, can you determine which relay is clicking?
-Rod
Old 08-08-2011, 12:00 PM
Jaxom's Avatar
Jaxom
Jaxom is offline
will check plugs that go down to the trans angain when I get home, one of the relays clicks when the key is turned to start I will have somone help me so I can fined out witch one it is.
Brandon Brown112
06-11-2018 07:07 AM
eddie g
01-28-2011 12:27 PM
oarhead61
04-12-2006 02:13 PM
glcarpe
02-06-2006 02:07 PM
higgens
1997-2006 Expedition & Navigator
07-19-2003 08:54 AM
Quick Reply: '97 Ford Explorer XLT - Not starting
