I want to Paint the Bronco, So whats the plain Alan? - Ford Truck Enthusiasts Forums
Missouri Chapter Join Chapter , Leader:tcbofade
Old 08-07-2011, 10:26 PM
pintoches's Avatar
pintoches pintoches is offline
pintoches has a good reputation on FTE.pintoches has a good reputation on FTE.
Here is my thought, Alan then tell what you think.
For now I would just like it one color, So Im thinking Nason single stage factory pack in a blue close to what the bronco is now! just scuff and paint! Then as we can fix holes and dents just paint back with the same factor pack color!
Once all the body work is done we can finish sand an paint back to the factory color blue (with out white and trim)
I don't want a show truck paint job, but would like it to look good!
Old 08-07-2011, 11:30 PM
earthquake68's Avatar
earthquake68 earthquake68 is offline
earthquake68 has a very good reputation on FTE.earthquake68 has a very good reputation on FTE.earthquake68 has a very good reputation on FTE.
Spend the money and do the body work once and be done with it. The more paint you put on it, the more you have to take off. Nason is not very good paint. As a matter of fact, ...it sucks. I like shooting PPG and they have a cheaper line called Omni. It's still more than Nason, but it won't fall off the truck in six months either. Just put it in primer black if you want to work on it and drive it in one color. Then you can work on it and touch it up as you would like.
Old 08-08-2011, 12:07 AM
pintoches's Avatar
I would love to just do it once! but cant afford to pay you one lump some to do it!
And I don't know how to do body work right?
Old 08-08-2011, 08:55 AM
Well, painting it two or three times isn't the answer either. We'll work something out. I think a good coat of primer is the answer you're looking for. Even Nason paint isn't as cheap as a good primer. (operative word here is GOOD)
Another thing, I'd either get it done before it gets cold out, or wait until spring. You don't need any "work in progress" on salty winter roads. If you take all the chrome off, I think I could have it in color in a week. The truck really isn't that bad. Whenever you're ready, let me know. ...but let me get this '57 out of my hair first. I want to give it back to the owner by the swap meet so I can buy some parts.
Old 08-10-2011, 09:22 PM
pintoches's Avatar
When you say in one color in a week, what all you talking about doing?
what about just sealing it with a black sealer! and staring body work in spring?
Old 08-10-2011, 10:29 PM
From this....
To this...
...and yes, Black sealer/primer is fine. That way you (I) can do the bodywork whenever.
Old 08-10-2011, 10:47 PM
pintoches's Avatar
Can I spray the sealer my self, or is that some thing You want to do since you will be working on it later?
Old 08-11-2011, 08:09 AM
Nah, you can do it. Just make sure to prep the surface first. (sand and clean)
Old 08-11-2011, 08:12 AM
cyclopsblown34's Avatar
cyclopsblown34 cyclopsblown34 is offline
cyclopsblown34 has a good reputation on FTE.cyclopsblown34 has a good reputation on FTE.cyclopsblown34 has a good reputation on FTE.
Ches, do you still work at Slo Reilly? If so, I'd suggest using the Nason FulPoxy to give it corrosion protection if you've any bare metal. If you let Alan get the materials, the epoxy of his choice would be as good or better. I think you can tint most epoxy primer as well. I know I've tinted the Nason stuff before with no ill effects. The other option is check out Southern Polyurethanes, their epoxy primer and high solids clearcoat are the best I've used and they even have a black epoxy primer. Google search Southern Polyurethane and you'll get their website.
Matching the paint on door pillar Trim. alan.cassidy 1978 - 1996 Big Bronco 1 12-23-2009 09:11 AM
need gauge pod for overhead console alan.cassidy 1978 - 1996 Big Bronco 2 12-21-2009 03:20 PM
Painting airbag cover alan hodges Paint & Bodywork 2 10-21-2006 07:28 AM
Crew cab ranger alan hodges Ranger & B-Series 9 10-12-2006 08:30 AM
do they sell trim touchup paint? Alan'sExpy 1997-2006 Expedition & Navigator 3 01-30-2005 08:12 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
alan, blue, factory, fenstermaker, ford, nason, pack, sparta
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
