"HD cooling" radiator for 96 300?
Old 08-07-2011, 06:42 PM
speed's Avatar
speed
speed is offline
I called the parts store for a radiator for my 96 300 f 150. They had the "standard cooling" one (1 inch core) for $159.00 and the "HD cooling " (2 inch core for $129.00 Can you bolt the thicker radiator in witthout changing the shroud etc? sounds like a good upgrade and cheaper to boot!
Old 08-07-2011, 07:29 PM
dustybumpers's Avatar
dustybumpers
dustybumpers is offline
yes, I use that one, you have to mess around with the bolt on the shroud a little on the one side, I just drilled a hole and used a zip tie.
benwantland
01-29-2023 06:35 PM
vidaliaman
02-01-2017 07:06 PM
F350Kid238
08-27-2011 09:11 AM
NavyMIDN08
02-09-2007 12:35 PM
66MercMan
06-12-2003 10:16 AM
Quick Reply: "HD cooling" radiator for 96 300?
