Idle
Idle
Probably the IAC valve, but could be the Throttle Position Sensor, the Mass Air Sensor or the Vehicle Speed Sensor.
I would clean the IAC and if that doesn't do it scan for codes.
If you have messsed with the idle speed set screw you may have to go through the idle setting procedure.
