72 ford 1 ton axle id tag (translation) - Ford Truck Enthusiasts Forums
Old 08-07-2011, 06:00 PM
fromm's Avatar
fromm fromm is offline
fromm is starting off with a positive reputation.
1972 Ford 1 ton Rear end id tag number. 603201-13 02ta-haa 4:10
I assume it has 4:10 gears what does the other numbers mean.
Is this rear end a positrac (traction Lok) rear end or limited slip
Old 08-09-2011, 12:42 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Is this a Dana axle?
Axle Identification Chart
Scroll down all he way here for number locations:
Differential identification charts
More on Dana id info, numbers etc:
http://www2.dana.com/pdf/AXSM-0053.pdf
Help new excursion owner out please Mike Barton 1999 to 2016 Super Duty 1 04-28-2016 10:42 AM
rear tag number what ratio ? Selfhl1 1987 - 1996 F150 & Larger F-Series Trucks 19 10-23-2015 09:44 AM
HELP!! Rear axle ID tag question Farmtruckn 1967 - 1972 F-100 & Larger F-Series Trucks 7 08-02-2015 01:30 PM
Gear ratio identification okie72 1973 - 1979 F-100 & Larger F-Series Trucks 8 02-02-2014 10:46 AM
rear end tag numbers fordman300 Clutch, Transmission, Differential, Axle & Transfer Case 1 04-11-2004 09:24 PM
Tags
410, 72, axle, diff, differential, duty, ford, heavy, id, identification, rear, tag, tags, ton, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
