Overdrive button on gear shift - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-07-2011, 05:48 PM
amyr61 amyr61 is offline
amyr61 is starting off with a positive reputation.
Hello! I have a '99 F350 Diesel. There is an button on the end of the gear shift labeled "overdrive" I have a "Tow/Haul" button on my 3/4 suburban which my ex said to enable when hauling my 4 horses. I thought this "overdrive" button was the for the same thing, but someone told me no. Can someone tell me what the overdrive button is for and when should I use it?
Amy
Old 08-07-2011, 06:30 PM
christopherdrop's Avatar
christopherdrop christopherdrop is offline
christopherdrop is starting off with a positive reputation.
Quote:
Amy
I believe that button simply disables oversdrive (4th) for engine braking and to avoid hunting for higher gear while pulling.
Old 08-07-2011, 06:32 PM
spud57's Avatar
spud57 spud57 is offline
spud57 is gaining momentum as a positive member of FTE.
It is an OD off button for your transmission. When it is activated it prevents the transmission from shifting into overdrive. You will now only upshift to 3rd. When to use it? When pulling heavy loads and the transmission does not want to stay in OD for very long. If you find the tranny is hunting a lot between 3rd and OD. Press the button to lock out OD. Continual shifting is what will effect the longevity of the tranny.
Your RPMs will climb about 500 but will have some but minimal impact on fuel mileage.
Your Tow-haul button on your suburban is totally different. When activated, it changes the shift points so the engine stays in each gear a little longer to take advantge of the slightly higher RPMs.
Also, welcome to FTE.
S
Overdrive Light BLINKING (F250 SuperDuty) campbell99 1999 to 2016 Super Duty 73 01-11-2017 06:52 PM
Truck not going into overdrive hack 96' F150 lievense81 1987 - 1996 F150 & Larger F-Series Trucks 1 08-26-2015 07:38 PM
'01 F250 7.3L overdrive shutoff problem... MTGunner 1999 - 2003 7.3L Power Stroke Diesel 15 06-11-2010 07:08 PM
overdrive button nflfreak43 1987 - 1996 F150 & Larger F-Series Trucks 16 03-15-2009 02:10 PM
overdrive flashes "off" risky97psd 1994.5 - 1997 7.3L Power Stroke Diesel 58 09-13-2008 07:37 PM
Tags
1999, 2000, 2008, button, explorer, f250, ford, gear, overdrive, parts, seperate, shift, switch, taurus, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
