Need starter info
Need starter info
I am coming to the end of my 2.5 replacement but having trouble wiring the starter. The wiring diagram shows two red wires going to the solenoid. The end of my wiring harness has one red wire, one black/orange (pinkish) wire, and the yellow/blue wire. I assume the yellow/blue wire bolts onto the smaller post but do both the red and black/orange wire bolt onto the same post? Also, there is a bracket near the end also, does this bolt to a bell housing bolt? And, the black/orange wire is at least 6" longer, has a rubber boot and a christmas tree fastener as if it slides into a hole but I can't find anyplace where it would go. Does this loom go under the left side motor mount and follow along the bottom in between the oil pan and crossmember? Please help, this project has taken way too long already.
I was mainly wondering where it routs. At first I had the loom hugging the rear of the oil pan between the crossmember. Then had it hugging the front of the pan but still not enough clearance. Then I found space under the pan right behind the steering rack. I believe it is the right spot.
GotFord83
09-13-2012 07:32 AM
ferguson777
32
07-07-2012 06:27 PM
