226 carb linkage - Ford Truck Enthusiasts Forums
226 carb linkage
Old 08-07-2011, 02:24 PM
blsd49's Avatar
blsd49 blsd49 is offline
blsd49 is gaining momentum as a positive member of FTE.blsd49 is gaining momentum as a positive member of FTE.
226 carb linkage
Does anyone have a picture of the carburetor linkage and spring on a 6 cyl flathead? Thanks, Brian
Old 08-07-2011, 05:13 PM
badger_hound's Avatar
badger_hound badger_hound is offline
badger_hound is gaining momentum as a positive member of FTE.
226 carbs
Here you go. Note that the car and truck carburetors are slightly different from one another, even though they are both Holley model 847-FS carbs. The choke lever on the truck carb has a ball and socket connection, but the car carb has a screw clamp connection. The one on the right came off of my truck, so some previous owner must have changed out the choke cable connection in the past as well.
The air horns are also different. The truck air horn has a ridged flange at the top and the car air horn does not.
Anyhow, I got all of this info from the Holley 847 repair manual I found at the old car manual project (Holley 847 Downdraft Service Manual / H847-19500001.jpg), so take a look.
Here's some closeups of the truck carburetor linkage:
Hope this helps.
Old 08-07-2011, 05:19 PM
Here's a couple of photos showing how the carb was hooked up before I pulled it:
Old 08-07-2011, 07:36 PM
blsd49's Avatar
Thank you badger-hound; the installed ones are what I was looking for. Mine is set up the same way, just always thought that maybe the spring should go back to the firewall but I guess not.
Ball Joints. bma2001 1999 to 2016 Super Duty 2 02-19-2015 06:14 PM
Hi Brian B in NJ New Member Introductions 1 12-12-2014 12:25 AM
front hitch Brian 2002 1999 to 2016 Super Duty 7 12-11-2014 05:38 PM
2b carb question stumble on takeoff brian1080 1973 - 1979 F-100 & Larger F-Series Trucks 0 03-05-2013 08:18 PM
location of starter solenoid 2000 Expedition shadowcatcher Electrical Systems/Wiring 4 09-29-2003 06:04 PM
Tags
226, 63, bronco, cable, carb, carburetor, choke, f100, flathead, ford, lever, linkage, pickup, pull, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
