1997 F-150 5.4 with new battery won't turn over - Ford Truck Enthusiasts Forums
Old 08-07-2011, 12:30 PM
Lumberjack97 Lumberjack97 is offline
Lumberjack97 is starting off with a positive reputation.
Question 1997 F-150 5.4 with new battery won't turn over
Just a frustrated newbie here trying to determine why my truck won't turn over. Been running rough for last couple of months, replaced a couple of coil packs. (No codes indicated) Some improvement. Last two trips out, the starter was dragging and hesitating a little before the engine fired. It's been very hot here in the Carolinas (like everywhere else), so I thought it was the battery when I got the clicking sound and no start. Bought a new battery yesterday and now it still clicks, and has a check engine light. Charged battery and have same result. Truck has 50K on it. I'm dead in the water at home with no code reader.
Any help would be much appreciated.
Old 08-07-2011, 02:11 PM
enriched&beyound's Avatar
enriched&beyound enriched&beyound is online now
enriched&beyound is starting off with a positive reputation.
might be just a poor connection on the starter. or bad ground.
then there is the solenoid that maybe iffy or at least the connection there.
are you loosing any fluids?
getting the codes read would be a plus
Old 08-07-2011, 03:08 PM
No fluid loss. I was going to take the starter out next and have it tested, but was trying to make sure I'm do this in the right order of diagnostics (cheapest fixes first). If it's not the battery, I hope I can return it. Is the solenoid a stand alone part on these trucks or an integral component of the starter itself? I wonder if I can borrow a code reader from somewhere......
Old 08-07-2011, 05:52 PM
yep your thinking right simple and easy stuff 1st. Typically on electrical items (your battery), you can't return them...but they might? Just don't hold on to high hopes for that
getting the starter tested is a good step...this way you can see and check the connections there.
yeah the soleniod is stand alone unit...should be one on the fire wall. then there is the breakers/main fuse right beside that (just right of the battery) and checking the relays too.
if the starter and everything checks good...then it maybe a fluid filling a cylinder...stuck open injector...or leaking headgasket
Old 08-07-2011, 08:14 PM
Thanks! I'll check them out tomorrow and keep my fingers crossed!
Ticking/clicking under dash ? erik_bishop 1999 to 2016 Super Duty 7 03-30-2015 10:34 PM
Replaced batteries, truck won't start six6six 1999 - 2003 7.3L Power Stroke Diesel 3 09-17-2014 12:52 PM
86 F150 Starting issue paulwjax 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 01-20-2014 12:38 PM
Crank how long before batteries die mrberg89 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 01-11-2014 12:36 AM
can a starter get to cold arkredneck 1994.5 - 1997 7.3L Power Stroke Diesel 11 01-08-2010 01:45 PM
Tags
1996, 1997, 54, battery, battetry, clicks, engine, explorer, f150, ford, intake, start, truck, turn, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
