97 f350 front axle c-clips
08-07-2011, 09:09 AM
on
Hi guys, Does the pinion have to be removed in order to get the c-clips out to pull the axle?
08-07-2011, 09:27 AM
No c clips in the ft axle, remove the hub, rotor, and spindle then they slide right out.
08-07-2011, 09:30 AM
on
I tried that, but it sure feels like there are c-clips holding the axle shaft in. This is a dana 60 and I thought they had c-clips?
Thanks for the reply
08-07-2011, 12:30 PM
No c-clips on a Dana 60. The seals may be dragging a lilttle, just pull harder
08-07-2011, 02:56 PM
on
Thanks Brad. I got it out, just had to give it a little juice.
08-07-2011, 03:36 PM
on
One more question. What are the torque specs for the upper and lower ball joints. I know there is a sequence, bottom first then top, then bottom again. But I cant remember the torque specs for them. I tried searching, but all I came up with was for the TTB axle. I thought the f350's had a different spec. Appreciate the help.
08-07-2011, 04:50 PM
the Dana 50 and Dana 60 both use the same BJs. I make them as tight as I can make them with a 1/2" breaker bar
Radster
24
06-12-2013 07:41 AM
86pullerf350
08-17-2010 10:28 PM
ltr450
05-01-2008 07:10 PM
scottie2hottie
16
12-05-2006 07:07 AM
fordper4mance
02-02-2004 10:26 AM
1999 ,
2011 ,
4wd ,
97 ,
axle ,
clip ,
clips ,
differential ,
f250 ,
f350 ,
ford ,
front ,
ranger ,
spindle ,
trucks
