Hydraulic Jack Rebuild - Ford Truck Enthusiasts Forums
Old 08-07-2011, 12:07 AM
eman92082's Avatar
eman92082 eman92082 is online now
Monkey-Face in Your Face!
eman92082 has a great reputation on FTE.eman92082 has a great reputation on FTE.eman92082 has a great reputation on FTE.eman92082 has a great reputation on FTE.
My Harbor Frieght Engine Hoist Jack isn't lifting beyond halfway, If I add oil it works so I assume an O'Ring is leaking. Probably from lack of use.
It's a generic Cylinder Jack. Before I tear into it is there anything I need to know or special tools beyond C-Clip Pliers ? Any experience out there ?
Thanks
E-Dawgie
Old 08-07-2011, 12:19 AM
fixnair's Avatar
fixnair fixnair is offline
fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.
Pretty straight forward. Just be aware of ***** in little holes which like to fall out while you are not looking. Or come out while you are cleaning it in the solvent tank. If you don't get them back into their proper holes you can forget about it ever working again.
When you go back together use hydraulic oil. DO NOT USE BRAKE FLUID! That will ruin all the soft parts.
Old 08-07-2011, 12:27 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
I'd be interested in parts availability. My engine hoist (older HF unit) likewise leaks down, but doesn't "use" oil (no leakage visible). Inquiries at local hydraulic shops haven't panned out, they say there is no standardizatiion on parts. HF says "maybe" I can buy a whole new ram, but they've never ordered one and they suspect it costs as much as a new hoist.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
