Where or how do I get this "tuned".
Make a long story short- I just had the FICM replaced and the oil cooler pump replaced on my 06 - 6.0 turbo. While they were at it, I had them install a Sinister EGR cooler eliminator kit. They left the EGR in, so I wouldn't get codes for an EGR failure problem. What I'm getting now is code for poor EGR flow. (Figures since there is no flow by the EGR now). How can we eliminate getting this code? I'm new to diesel so I've been told I need to get a custome tuner. Any one want to help explain this to me?
Other than clearing the codes, which seems to only last about 5 miles in this case, can a dealer tune it so the code doesn't come up and the check engine light does not come on?
Mine comes on only about once a week, and usually on secondary roads around the 45 - 55 mph area when I'm accelerating. But I guess every vehicle / driver / road is different so I don't know if there is a standard.
That I don't know. I doubt it though because that might come under the heading of altering the function of the emmissions, which they probably don't want to mess with.
When you want to change any of this, there are a couple of options. The first way would be to change the equations in the factory processor. Another way would be to "intercept" the vRet and and change that value to get the result you want ( sorta spoofing it). Most people prefer tuners that work the first way. Copying software from the truck and storing it in the tuners memory (as a back up) and replacing it with software from the tuner. There are lots of threads here about which tuner is best and who's software to buy. You'll have to research a little to figure out which one you want. I'm not sure what the PCM is looking at to determine EGR flow is low. It may be simple as a sensor in the EGR valve monitoring it's position and seeing that it never opens or it could be a combination of other sensors like manifold pressure (MAP) and the drive signal to the turbo actuator being used in a equation that results in an out of parameter EGR. Either way, a tuner/software strategy could fix this in a few different ways. (1) Replace the equation resulting in a value that is in parameter. (2) Substitute a fixed value that is ok. (3) change the upper and lower limits so that any value is in range. (4) Force the PCM to use a look-up table that has only values that are in parameter or, (5) Tell the PCM to ignore this value. The end result is the same,,, no check engine light! *
There are lots of options when you are modifying software. Thats why it's important to choose wisely. Hope I answered your question in there somewhere.
The dealer will not tamper with emmision equipment because it isn't leagal. You will need to get a custom tunner to turn off the cel. I would recomend either SCT with custom tunes from Matt at Gearheadautomotive, or Eric at innovative diesel. The only other one I would recomend is the Spartan Phalaix with there custom tunes.
My truck is a Feb 2003 build date, and the egr delete is a Liberator Performance delete kit. I don't know if that makes any difference.
TxFord0207
08-08-2012 04:06 PM
