1990 F250 460 fuel issue - Ford Truck Enthusiasts Forums
Old 08-05-2011, 09:04 PM
Caveman84 Caveman84 is offline
Caveman84 is starting off with a positive reputation.
last week, drove bout 35 miles, parkede, stacked wood fer bout 2 hours, drove home, parked for bout 5 minutes, came back... wouldnt start, not gettin fuel, found the relays, but 3 of em are out from under the cover, noticed they each are a different color, Im guessin based on another post I read, that the fuel pump relay is green, I would like to confirm this, and if there might be any other potential causes. I ve always struggled in the diagnostic side of workin on cars and trucks, so any help is much appreciated
Old 08-05-2011, 10:22 PM
DBGrif91's Avatar
DBGrif91 DBGrif91 is offline
DBGrif91 is gaining momentum as a positive member of FTE.DBGrif91 is gaining momentum as a positive member of FTE.
For such a sudden onset of a problem, I'd be checking the fuse[s] before I got into the relays.
Old 08-06-2011, 08:19 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Yes the relay should be green if somebody has not up dated it to the newer stile.
Old 08-06-2011, 02:30 PM
subford:thanks hoss, I can chalk one up to dumb luck, I figured green was the one, I'm only the second owner and still under 100k, so the chances of an update are pretty slim.DBGRIF91: I checked on power to the relay, and thats good, so I figure its the relay, but none of the other relays will fit, so Im still not 100% sure. I cant seem to find the fuse, then again I aint exactly the sharpest crayon in the box. I searched youtube for testing relays, but still having trouble comprehending how to go bout it. Any simple ideas?
Old 08-06-2011, 09:06 PM
subford's Avatar
Most of the time the problem is with the relay socket and not the relay.
Check the wires under the socket to see if they are attached good.
If OK ground pin #6 of the self-test plug and turn on the key. each time pin #6 is grounded the fuel pump relay should click.
There are no fuses in the fuel pump circuit. It uses what is called a fuse link and is coming off the battery side of the starter relay on the passenger finder. The fuse link feeds a Yellow wire that goes to the common contact point on the relay.
When you check the wires under the socket make sure both the yellow wire and the red wire have power on them with a test light with the key on. The brown relay should click each time the key is turned on and then fall out when you turn the key off. It supplies the red wire at the fuel pump relay.
The relay and showing bot the OEM and the updated relays.
2004 F-250 5.4 crank no start. Cperk 1999 to 2016 Super Duty 5 01-02-2017 12:21 PM
wont run, new fuel pump, new crank/cam sensors, good relays/fuses etc etc..wat gives? SYKOLINCOLN 1997 - 2003 F150 23 09-05-2016 01:03 PM
Follow up to post with video al0311 1999 - 2003 7.3L Power Stroke Diesel 1 01-29-2016 06:57 PM
1356 tcase.... Gear splitting? 00Boss 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 11-12-2015 07:22 AM
Intermittent idle? fenix1 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 1 01-27-2013 05:42 PM
Tags
1990, 1990f250, 460, 72, diesel, f150, f250, ford, fuel, models, motor, pump, transmission, truck, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
