1952 FORD f1 PICKUP
1952 FORD f1 PICKUP
Category: Accessories
Price: $13000
Private or Vendor Listing: Private Listing
Item Condition: TX
New 12 volt wiring harness New sun visors installed
New shoulder seat belts added New Water temp sending units
New king pins installed Turn signals added
New belts New fan shroud added
New under engine pan New pitman arm
New wood in bed All lights have been changed to 12 volts
New cowl to hood seal New drag link and parts
New Thermostats both sides New Thermostat housings
Dual exhaust pipes New fuel pump
New carburetor New fuel line and filter
New temp gauge New Horns
New tie rod ends New center tie rod link
New ignition coil Flame Thrower epoxy filled
Radiator has been taken to shop and rotted out
New Oil pressure sending unit
Gas tank has been cleaned inside and out
New gas sending unit New windshield wipers and arms
