you mean in the back, on the driver's side, near the firewall? Could you explain?
Also, where you said "but if will fit", did you mean "but it will fit"?
I have considered this just for the hell of it. But body work might be in 2 or 3 years.
....Yeah it should have read , but it will fit , i just had to grind a little off the lower on the drivers side front for clearance for the fuel rail....
do u think one reason oil is getting out is because of the pcv valve.. should i eliminate it? ....i have measured anything yet but like i said i have ported gt40s with stud mounted 1.6 proform rockers and a stock upper/lower intake..and trickflow stage 1 cam
like i said the only reason i havent gotten taller covers is beacuse i want to make sure they clear everything...one question about the pcv.. if its bascially sucking in oil would that cause it too run rich at times?
Sounds like you might have alot of blow by , do you get smoke out of the pipes , i never had a problem with the pvc valve sucking up oil , for the rich condition i would check the FP regulator and pull the codes
