Fuel Line Repair Help - Ford Truck Enthusiasts Forums
Old 08-05-2011, 03:26 PM
FastGilla FastGilla is offline
FastGilla is starting off with a positive reputation.
I have a 1989 F150 4x4. I recently had work done to the rear suspension. I had a shop(first mistake) put new leaf spring hangers and shackles in to replace the rusted out ones. After a 2 day nightmare trying to find the correct parts I finally got it back and was satisfied with the suspension repair. What I was not satisfied with was the broken brake and fuel lines. Well after talking to the manager he agreed to pay for repairing the lines, but I will not let them touch the truck again(if you want it done right, do it yourself). I already replaced all the brakes lines from about mid truck back included the flex hose to the axle. Now its time for the fuel lines, but I'm stumped. I've only ever had to deal with steel line, which would be an easy fix. This Ford has nylon and its broken in about the same spot on both the feed and return lines. I've never had to repair a nylon fuel line before and I don't want to mess it up. How hard is it to repair the lines? I know there are repair kits to repair sections of the line, and the area that is bad is small, no wider than a 1/2". I've never seen it done and I am completely at a loss here. The guy at the shop said something about having to stick the end in boiling water and then quickly install the coupler to fix it. I have no idea and I need some advice. Thanks in advance.
Spark Plug thread repair. With Photos tmehrkam Modular V10 (6.8l) 43 05-06-2016 07:21 AM
Wheel damage tseekins 2009 - 2014 F150 7 07-02-2015 11:41 AM
Need help clearing a code 311 Nothing Special 1987 - 1996 F150 & Larger F-Series Trucks 9 08-21-2014 09:29 AM
04 F150 FX4 10 years later mrshark 2004 - 2008 F150 14 07-18-2014 10:20 PM
I'm done with my 2008 F250. mike_pop 6.4L Power Stroke Diesel 26 11-05-2013 06:43 PM
Tags
1979, 400, 89, broken, f150, fix, ford, fuel, gas, line, nylon, ranger, repair, repairing, series
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
