Slow fuel gauge - Ford Truck Enthusiasts Forums
Slow fuel gauge
Old 08-05-2011, 01:17 PM
nnak58's Avatar
nnak58 nnak58 is offline
nnak58 is starting off with a positive reputation.
Slow fuel gauge
So I threw some gas in the Ex yesterday... I was just between 1/2 and 1/4 and I put in about 17 gallons. I got back in it and the gauge moved to 1/2. This morning as I drive 25 miles to work, it finally slowly crept up to just above 3/4. Anyone else have this issue?
Old 08-05-2011, 04:15 PM
saz2686's Avatar
saz2686 saz2686 is offline
saz2686 has a great reputation on FTE.saz2686 has a great reputation on FTE.saz2686 has a great reputation on FTE.saz2686 has a great reputation on FTE.saz2686 has a great reputation on FTE.
If I add fuel without first switching the ignition off (let the truck run) the gauge moves up very slowly or very little. My gauge has never taken more than five or ten minutes to get accurate. If I do turn the ignition off before adding fuel the gauge is accurate as soon as I switch the ignition on. Strange that it took so long for yours. Just curious, has the gauge dropped accordingly to fuel consumption?
Old 08-05-2011, 10:02 PM
1975StroppeBaja's Avatar
1975StroppeBaja 1975StroppeBaja is offline
1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold
That happened on my SD one time when I turned the key on while filling up.
It must blow its mind if the key is ON and the amount of fuel is *increasing*
Old 08-06-2011, 08:57 AM
X_Hemi_Guy's Avatar
X_Hemi_Guy X_Hemi_Guy is offline
X_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputation
Mine does and has always done the same thing.
I always write down my mileage when filling up...if I don't get the key "off" before it hits somewhere between 1/2 and 3/4 full gallon wise...and the key is in the "ACC" position or truck is running...it takes a long time for the gauge to reach "full"...and mine "creeps" like the OP's does if it gets hung up lower than it should.
Joe.
Old 08-06-2011, 09:28 AM
nagetech nagetech is offline
nagetech is gaining momentum as a positive member of FTE.
I have that issue with the X and HAD that issue with my explorer. I gave it 3 separate treatments of Chevron Techron, and the issue disappeared in the explorer. I wonder if the same results can be had with the X....
Thanks for bringing this up! *adds it to his list of things to do*
Old 08-08-2011, 10:02 AM
Splash67's Avatar
Splash67 Splash67 is offline
Splash67 has much to be proud ofSplash67 has much to be proud ofSplash67 has much to be proud ofSplash67 has much to be proud ofSplash67 has much to be proud ofSplash67 has much to be proud ofSplash67 has much to be proud ofSplash67 has much to be proud ofSplash67 has much to be proud of
I have had the same thing multiple times...but it always adjusts to the correct level when given time...it is annoying when trying to track mileage, as I ahve spilled diesel once or twice thinking it wasn't full...oops...
Old 08-08-2011, 10:04 AM
Splash67's Avatar
I've run additives many times and it makes no difference at all (on the fuel gage that is)...
1947 6v to 12v conversion **comments please** marine1200 1947 and Older Ford Trucks 15 04-24-2015 09:20 AM
Anyone filled in their 48-50 instrument cluster? Frank-1 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 11-03-2014 04:41 PM
Gas Gauge Problem xd2200 1999 to 2016 Super Duty 0 06-13-2014 02:41 PM
Fuel Gauge Accuracy tractoman 1994.5 - 1997 7.3L Power Stroke Diesel 5 05-08-2014 02:22 PM
fuel gauge stuck on 1/2 mark Rbuller24 1973 - 1979 F-100 & Larger F-Series Trucks 15 06-11-2003 07:29 PM
Tags
05, diesel, escape, excursion, ford, fuel, gauge, gauges, responding, running, slow, sluggish, switch, truck, wrong
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
