Adding Power Mirrors??
Old 04-27-2013, 01:30 AM
Lightning LA's Avatar
Lightning LA
Lightning LA is offline
I have a 1995 F-150 XLT,and it doesn't have Power Mirrors.And I'd like to add them,but I'm not sure what all I'd need to do it,and how to do it.I know I'd need the new Switch piece,and the Replacement Power Mirrors.But not sure what else..I did a Search but couldn't really find anything..So any Help will be Greatly Appreciated...
Old 04-27-2013, 05:59 AM
SideWinder4.9l's Avatar
SideWinder4.9l
SideWinder4.9l is offline
You'll need the correct door panels also.
Old 04-27-2013, 10:48 AM
Lightning LA
So you need the whole new Door Panels to add Power Mirrors? If you don't mind can you explain this to me,also is there Motors you need to....Thanks...
Old 04-27-2013, 11:33 AM
SideWinder4.9l
You need the interior panels. Manual window door panels are different than power window panels.
The motors are riveted into the door sheetmetal itself; So you'll need so drill a few holes to mount the motors on.
Old 04-27-2013, 12:36 PM
Evan_P's Avatar
Evan_P
Evan_P is offline
Power mirrors Sidewinder, not power windows... He wont need new door panels or to remove the window motor...
Old 04-27-2013, 01:11 PM
kowboy1's Avatar
kowboy1
kowboy1 is offline
Does a truck without power mirrors have the proper wiring inside the door to connect to the mirrors and switches?
Old 04-27-2013, 01:13 PM
Evan_P's Avatar
Evan_P
Evan_P is offline
I'm not sure if later ones did, but my 1992 does not have the wiring for them.
Old 04-27-2013, 01:41 PM
SideWinder4.9l
DAMN. Definantly wasn't firing on all cylinders.
My bad.
Old 04-27-2013, 01:43 PM
Evan_P's Avatar
Evan_P
Evan_P is offline
My bad.
No harm done.
Old 04-27-2013, 03:05 PM
Lightning LA
So what all will I need to get it done? Like I said I need the Power Mirrors.The Switch,and Switch Panel.And I saw a Wire Plug piece on e-bay,but I'm not sure what it's all about...And wouldn't the Motor be in the Mirror???
Old 04-27-2013, 03:10 PM
Evan_P's Avatar
Evan_P
Evan_P is offline
I am unsure of exactly what you would need. For this very reason, I haven't bother to try and put power mirrors in my truck. I would take off your door panel and look for the white plug in this picture. It shouldn't have anything plugged into it. If it isn't there, you may need a whole new door harness....
Photo courtesy of Steve83 @ Supermotors
Old 04-27-2013, 03:24 PM
Evan_P's Avatar
Evan_P
Evan_P is offline
Well after some quick digging, it looks like you will need the mirrors, the new switch panel for the driver side, the switch and the entire door harness's for both sides. Once you have those, it should be plug-n-play.
Old 04-27-2013, 04:54 PM
Lightning LA
Where would you get the wiring Harness? I know probably a Junk Yard would be a a good spot to find them,but the problem with that is there's no Junk Yards near me.Is there any Junk Yards that do Online Sales? Or would a new finding a new one be better??
Old 04-27-2013, 05:04 PM
Evan_P's Avatar
Evan_P
Evan_P is offline
You could try car-part.com, but im not sure you can search that part up. You wont find the harness new. Your best bet is a junk yard...
Old 04-28-2013, 06:45 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
The drivers door harness does NOT have a plug separating it from the truck harness. The power window/mirror harness is ONE PIECE from the drivers door to the passenger side of the cab. there is a plug in piece for the passenger door.
That harness for the cab is separate from the dashboard harness, BUT you need to remove the dash to get it out. It is JUST below the windshield
Quick Reply: Adding Power Mirrors??
