1991 F-series fuel pump control schematic - Ford Truck Enthusiasts Forums
Old 08-05-2011, 06:40 AM
BuickBrian's Avatar
BuickBrian BuickBrian is offline
BuickBrian is starting off with a positive reputation.
I am working on a 1991 F250 that is not getting power to the fuel pumps. I have a 1989 truck that is mine and have the service manuals for it, but the wiring and colors all changed for the 1991 model since they switched to having the high pressure pumps in the tank. Does anyone have a 1991 factory service manual that can scan the page for me that has the schematic drawing for the "fuel control system" I need this so I can trace down where the problem is. It has all the wire colors labeled on the drawing. My 1989 manual has an excellent schematic drawing in the fuel system section, it is just not correct for this 1991 I am working on.
Old 08-05-2011, 07:04 AM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
http://www.ford-trucks.com/forums/10...mp-wiring.html Should be similar to the diagram posted by subford in this thread.
Old 08-05-2011, 07:19 AM
BuickBrian's Avatar
Thanks! I think that is correct. I will know when I get home tonight and compare the wiring colors at the relay to this drawing.
Factory Tach Inop, Wiring Color Question jas88 1987 - 1996 F150 & Larger F-Series Trucks 15 08-04-2016 12:59 PM
Wiring schematic for 2002 F-150 XLT 4x4 5.4L West715 1997 - 2003 F150 1 07-21-2016 05:31 PM
87-Anyone know TRUE location of coolant temp sender? NO 'they' don't! Fixnstuff Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 09-16-2015 04:18 PM
is there NO!! 38 or 33 Gal. rear tank for a 1991 F- 250 351w kidkyle21 1987 - 1996 F150 & Larger F-Series Trucks 19 11-19-2011 08:54 AM
1991 F150 cruise control problem sarahN Electrical Systems/Wiring 9 04-11-2008 07:55 PM
Tags
1991, 91, diagram, f150, f450, ford, fuel, high, line, pickup, pressure, pump, schematic, system, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
