Australia Chapter Join Chapter , Leader: ChunderDownUnder
Aussie - what do you tow behind your F-series?
Old 08-11-2015, 04:33 AM
Kramer73's Avatar
Kramer73
Kramer73 is offline
HI Blue
I just have to ask.
What is the large black metal box that is on the inside of the chassis rail in the last picture? Is it a long distance fuel tank?
Thanks
  #77
Old 08-11-2015, 06:05 AM
Blue7.3's Avatar
Blue7.3
Blue7.3 is offline
Originally Posted by Kramer73
HI Blue
I just have to ask.
Yes it's a long range fuel tank, F250 2001-2007 SWB D/Cab
  #78
Old 08-12-2015, 04:12 AM
Kramer73's Avatar
Kramer73
Kramer73 is offline
Thanks Blue
Does it go up over the drive shaft, or only on the right hand side of it.
Any chance you know the width of the tank?
Thanks
  #79
Old 08-12-2015, 04:39 AM
Blue7.3's Avatar
Blue7.3
Blue7.3 is offline
Yes it only goes over to the drive shaft and holds 125 ltrs iirc, i can get the dimensions for you tomorrow if you like.
  #80
Old 08-12-2015, 04:47 AM
Kramer73's Avatar
Kramer73
Kramer73 is offline
Thanks Blue
That would be very much appreciated.
  #81
Old 10-01-2015, 05:41 AM
ozdatman's Avatar
ozdatman
ozdatman is offline
Just towed this across from WA to tassie
  #82
Old 10-02-2015, 12:48 AM
Patchy 73's Avatar
Patchy 73
Patchy 73 is offline
Epic trip, 4000 kms Plus, or double that if you had to go over to get it
Did it tow all right
Cheers,
Patchy
  #83
Old 10-04-2015, 06:50 AM
ozdatman's Avatar
ozdatman
ozdatman is offline
Cheers,
Patchy
Just from WA. It was tough on the old girl, had 4-5 ton on board. Blown cooling hose, fuel return line leak, three blowouts(because of the weight I think) and fried the old c6 5 km from the destination. It was acting up for the last 2000km to be fair on it.
  #84
Old 10-07-2015, 11:32 PM
BigF350's Avatar
BigF350
BigF350 is offline
Epic trip.
Looks like a fair bit of weight on the rear axle, definitely want to make sure you had your tyre pressures up!
  #85
Old 11-16-2015, 03:30 PM
ozdatman's Avatar
ozdatman
ozdatman is offline
Originally Posted by BigF350
Epic trip.
Yes, the trailer was a bit nose heavy. Ran 50psi in all the tyres,
  #86
Old 04-27-2019, 04:28 AM
Fraree's Avatar
Fraree
Fraree is offline
Originally Posted by Fraree
Don't own Patrols anymore, so I'm not offended
The original exhaust on 7.3 V8's sound more like a whistling fart
Hopefully some changes will improve the whole deal
Been a while since I've been on here ("faecesbook" seems to have killed forums) Fitted a turbo style muffler to my ex ambo a while back along with the "safe tow" tune. Now sounds like a V8 Scania down the highway
  #87
Old 04-29-2019, 03:55 AM
Fraree's Avatar
Fraree
Fraree is offline
Did a bit of a trip with the van over the Christmas break. The factory settings, don't really cut the mustard while towing 3 ton. Talbingo mountain was a bit of an effort. I've got a Superchips 1705 tuner but there's no power to make it work. Out of the 2 ciggy lighters on the dash, one works & the other doesn't, which would probably be power to the OBII port. Once away from the real big hills, we cruised fairly well.
Since then a new exhaust, put power to the second ciggy lighter which powered up the OBII port allowing the MAX micro tuner to power up, hence dialed in "safe tow tune" & new tyres (proper size) have made a difference!
  #88
Old 04-30-2019, 06:13 AM
Blackduck59's Avatar
Blackduck59
Blackduck59 is offline
My tow master
Ron94150
6.2L V8
190
01-15-2024 09:48 AM
moose79
05-07-2011 01:29 PM
05-04-2009 02:30 PM
Geaux-Fish
6.4L Power Stroke Diesel
04-24-2007 12:14 AM
proeliator
Offroad & 4x4
78
12-22-2005 07:13 PM
Quick Reply: Aussie - what do you tow behind your F-series?
